Most of my recordings on my EH59 look great, but I would like to adjust the brightness. The BVP seems to over soften the image more than I would like, and my AVT works well sometimes but not all the time. Is there a good alternative?
By "EHG59"do you mean a Panasonic DMR-EH59 DVD recorder?
By "BVP" do you mean a BVP-4?
By ""AVT" do you mean AVT-8710? Is your source copy protected?
Are you recording from VHS to your EH59? Are you recording a different source?
The Pansonic has a built-in line tbc and elementary frame sync on Input 1, but it's not being used if the AVT-8710 precedes the recorder. So I assume your VCR or source has a line tbc or doesn't need one.
Did you disable the EH59's DNR?- My sister Ann's brother -
Yes, yes, yes, not necessarily - using it for the proc amp mostly. I have the Video Filter as well for copy protection.
Using only VHS, some tapes actually look better over composite but I am using mostly s-video. I like the EH59's DNR and generally leave it on.
So what is a better way to adjust brightness? -
content affecting playback rate
By cheyrn in forum EditingReplies: 16Last Post: 22nd Nov 2014, 13:59 -
Add logo or watermark quickly without affecting video file size or quality
By MGadAllah in forum EditingReplies: 29Last Post: 27th Jul 2014, 10:38 -
MP4 to MKV without affecting the Video
By gonwk in forum Video ConversionReplies: 4Last Post: 30th Apr 2014, 18:11 -
How to change the Menu without affecting the structure of the originalDVD
By yozloy in forum Authoring (DVD)Replies: 1Last Post: 20th Dec 2011, 09:34 -
MKV - Remove unwanted audio without affecting any video quality
By ratatouille in forum Video ConversionReplies: 2Last Post: 18th Aug 2011, 14:55
