I was curious about this. I know theres a lot of copy protection stuff on DVDs that cds dont have. So if i got a dvd burner, would it do this?
Yes, but to a degree.
1.) Most DVD's are 9.4 gigs, while home DVD recorders only have 4.6 gig disks.
2.) You can never make a 1:1 copy.
A.) Rip the DVD, removing the macrovision and region protection.
B.) Demux the vob files
C.) Feed the mpeg files from the vob into authoring software -
actually Greg, 90% true.
I have a couple of far Eastern discs which are single sided and not copy protected. 1:1 copying worked fine. They were pressed commercial releases too.
However, as Greg said, the vast majority of commercial DVDs are dual layer 9.4Gbs so you cannot do a 1:1 copy. If you do come across any commercial DVDs that are only single layer chances are they will be copy protected so again, you cannot do a 1:1 copy.
Protecting a dvd from being copied
By arnold.iceman in forum Authoring (DVD)Replies: 4Last Post: 14th Aug 2010, 10:12 -
Copying an already copied dvd
By Angel87341 in forum MacReplies: 8Last Post: 12th Feb 2010, 15:54 -
Can't play copied DVD on DVD player
By mblaine in forum Authoring (DVD)Replies: 9Last Post: 4th Jan 2010, 08:01 -
Can a music CD be copied into a DVD?
By coody in forum AudioReplies: 6Last Post: 13th Oct 2008, 18:32 -
how do i prevent my dvd from being copied
By kareen_630 in forum Newbie / General discussionsReplies: 213Last Post: 6th Jan 2008, 09:16
