I'm trying to rip a dvd but I get 10 more frames than I should. If I rip with the subtitles I get yet another frame count.
I used option "same fps as original", constant frame rate. I tried also 25 (the dvd is 25), it didn't work better.
Is there a way to prevent that or is just due to compression and there is nothing I can do about it? I went for speed "very fast", is slower going to get me more precise frame count or not? I'm using handbrake btw.
thank you.
What you speak of is not the ripping but the converting.
You'll need to give us more specifics of the settings than that. Also, what are the media details of the source (beyond "25")?
Scott -
What does details mean? PAL 25 frames per seconds...region 2 dvd, converted into x264, same as source, constant fps, constant quality 20, x264 preset very fast, x264 tune none, h.264 profile main, h.264 level 4.0, mostly all the defaults...
10 more frames? 35fps? What software says that?
Does it play and look okey? -
10 more frames in total that is like 130510 instead of 130500. It looks okay but I need precision. I did it again with some yolo settings in advanced this time I'm 75 frames off.
I can see it in Vegas Pro. And handbrake tell me the number of frames of the DVD. No match. Before and after compression.
By zxcvfsdg13dvw in forum Video Streaming DownloadingReplies: 3Last Post: 21st Mar 2015, 05:42 -
Ripping All Key Frames
By Abbotta4 in forum Newbie / General discussionsReplies: 10Last Post: 22nd Jul 2014, 16:21 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 22:15 -
mencoder: seeking to frames (or cropping start frames)
By manchurian_candidate in forum LinuxReplies: 3Last Post: 13th Dec 2010, 09:53
