Does anyone here know if the software supports outputting burned layer0 and layer1 DVD-5 discs for submission to replication facilities to produce a DVD-9?
Results 1 to 10 of 10
DVDA does support DDP. You should probably ask your specific replicator regarding your other question.
2nd question's answer: one doesn't create a "burned" disc of a linked layer. Not only would layer 0 be "incomplete" on its own, but one could not even check a layer 1 disc for QC purposes, because it wouldn't have the IFOs (they reside at the beginning of layer 0).
No, it's been years since I sent a DL DDP out to a replicator, but IIRC you either burn a DDP to a DL disc (making sure you have enough room for the additional file overhead), or you save the DDP fileset to harddisk and send that to the replicator.
Scott -
Sure you can burn layer0 and layer1 each to a DVD5, see here:
http://www.hellmanproduction.com/dvd-authoring/how-to-create-ddp20-master-with-dvd-studio-pro.html
https://forums.creativecow.net/thread/145/869066
I know that GEAR Pro will do, I just wanted to know if DVDAPro will output the layer0 and 1 data separately so they can be burned to two discs -
Full disclosure: I don't know.
That being said, assuming Scott is right (generally a safe assumption,) why deliver on 2 DVDs when hard drive, thumb drive, data Blu Ray, or even online delivery of the undivided files is cheap and feasible? -
Ok, well yeah it doesn't have to be DVDs, I'm sure a flash drive would work too. I guess what I'm trying to determine is that with DVDAPro (which I've never used) that I don't need a DLT Machine to make a master to submit to a replication house.
Ok, does DVDAPro set layer breaks correctly? I remember with Adobe Encore years ago, you had manually change it using some freeware program, and a spreadsheet layer break calculator, it was a PITA...
IIRC, it USUALLY works, though not 100%. But I don't think you can be guaranteed of a seamless transition unless you control the encoding to the degree that it (layer break) start on an new GOP I-frame (with closed GOPs). Makes sense, if you think about it.
Better than Encore in my experience, but not perfect.
You can use other things than DLT now, but for replicated discs where you intend to include encryption, you should do the DDP or CMF image export option (in addition to the standard disc image).
Scott -
No, no encryption, it's pointless to encrypt DVDs when there are numerous programs that exist to decrypt them.
DVD Architect Pro 5.2 is placing black all around video
By cdavis in forum Authoring (DVD)Replies: 2Last Post: 18th Jun 2012, 17:26 -
Audio POPS! with DVD Architect Pro 5.0
By Dissonance in forum Authoring (DVD)Replies: 2Last Post: 21st May 2012, 16:45 -
DVD Architect Pro 5.2 error writing file?
By dabezt in forum Authoring (Blu-ray)Replies: 7Last Post: 30th Aug 2011, 08:55 -
Is there something better than DVD Architect 5 to use with Vegas Pro?
By ingeborgdot in forum Authoring (DVD)Replies: 11Last Post: 12th Dec 2010, 21:46 -
How to calculate signature of DDP images?
By casejustin80 in forum Newbie / General discussionsReplies: 0Last Post: 8th Oct 2010, 02:04
