Hello,
I bought a Blu-ray TV series season, and how to convert it to standard DVD using simple freeware tools? BTW, I will not be watching the standard DVD.
				Results 1 to 11 of 11
	See if avstodvd supports bdmv blu-ray folders. Rip with anydvdhd.
 Or else is probably vso blu-ray to dvd easiest or some dvdfab product...
 And I assume you are ripping for your family members. Then it's okey.
	@newpall
 Why don't we try answering rocky12's question? If you can't do that newpall, shut the hell up.
 @Rocky12
 You can convert Blu-ray to DVD-video using BD Rebuilder. Unfortunately, you will lose the menu when doing this, and with a series, you really need a new menu for the DVD in order to select each episode.
 I would suggest using MakeMKV to decrypt and rip each episode into a separate MKV file. Each episode should show up as a separate title in MakeMKV. Then use AVStoDVD to re-encode to the mpeg2 needed in DVD-video, and make a menu within AVStoDVD so that you can select individual episodes.
 Don't try to put more than 2hrs of running time on a single layer disc. This means you might have to burn two or three discs (or more) to get the entire series. Or you could put 3hrs or so on a double layer DVD (Verbatim brand only).Last edited by Kerry56; 17th May 2015 at 14:56.
  How to convert Blu-ray to standard DVD-Video (or MKV,MP4) using free toolsBy Baldrick in forum User guidesReplies: 4Last Post: 22nd Oct 2015, 21:39
  How to convert a Blu-ray to a standard DVD using free toolsBy Baldrick in forum User guidesReplies: 5Last Post: 11th Aug 2013, 22:50
  Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 04:35
  Any way easy to convert blu-ray and hd-dvd to standard def dvds?By tecnition_teds in forum Blu-ray RippingReplies: 40Last Post: 6th Mar 2011, 21:39
  convert non blu ray movie to blu ray disc???By dalmar6677 in forum Authoring (Blu-ray)Replies: 2Last Post: 31st Aug 2010, 19:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
						 Visit Homepage
				Visit Homepage
