I don't want to convert the subtitle into .srt or else.
Basically I'm trying to rip a dvd with handbrake and keep the closed/hardcoded subtitle within the video image. I can do that just fine. But now what I want is to be able to move the subtitle at a different position and if possible change the color also. Handbrake doesn't have this option. So I want to edit the dvd. Just the subtitles bitmaps.
"DvDSubEdit" does exactly that. But this program crashes when opening "full domain", or if I do file by file, I'm stuck at file 5. So it's worthless. I need another program like this bugs free.
Thank for very much if you can help me!
Results 1 to 11 of 11
I don't think you will find anything better/easier than dvdsubedit.
Are you sure your vob files works fine? Commercial dvd? Ripped how? -
You can easily change the colors of the subs while still in the DVD using PGCEdit. You can adjust the positioning using DVDSubEdit, which you seem to be having trouble with. Like Baldrick, I don't know of another program to do that. Not without extracting the subs for editing followed by remuxing/reauthoring.
Thanks for the replies. I'm more or less newbie at ripping.
Am I not supposed to just copy and paste the dvd folder on my hard drive then use dvdsubedit on these files? If so then it doesn't work. The program crashes in 2 different ways I'm doing it. "the application has stopped working". there is also many error that says "Inconsistant data in subpic. Unknown command, ignoring this subpic". It does that a few times and I manage to move the subtitle and write the file for the 4 first chapters but not the 5th.
I also had problem with Handbrake as the dvd seemed to be protected and the video was filled with squares initially. Yes it's a commercial dvd. I changed a dll and now that works but I still don't know how to move the subtitle. I don't want to use that OCR thing because sometimes there is a letter or two that are wrong. I want the exact text to the pixel, only at a different place. -
If I'm understanding you correctly, then the answer is 'no'. You first decrypt the DVD contents to the hard drive using a proper decrypter (and Handbrake doesn't qualify) before you do anything else with it. Not copy-and-paste.
What works? Now you can 'Open Full Domain' in DVDSubEdit?I changed a dll and now that works...
If DVDSubEdit is working for you now, you might want to apologize for that remark. It's a well-respected program.So it's worthless.
Have you bothered reading the very well written User Manual?...but I still don't know how to move the subtitle.
http://download.videohelp.com/DVDSubEdit/UserManual/helpfile.htm
Try reading Section 2, especially 2.7 and 2.8. -
I was just testing that. Remember, he wants to adjust the position with the subs still in the DVD. I tried to open the IFO of about half a dozen DVDs and BDSup2Sub said it couldn't find SUP files in any of them. Are you sure it's supposed to work with DVDs?
You need to extract the subs first,sometimes it's much easier this way then to spend a lot of time trying to do it directly.
@manono I did 2.7 and 2.8
But from my copy and paste I guess that's the problem then... Stupid me, I thought it was that easy.
"You first decrypt the DVD contents to the hard drive using a proper decrypter before you do anything else with it."
Can you tell me a proper decrypter that do that then? I guess I'll look around but thanks. -
If it's an older DVD, then DVDDecrypter. For newer DVDs with advanced copy protection, DVDFab HD Decrypter. You'll probably be safer with DVDFab.
I want your help: Change subtitle position
By mmkk in forum SubtitleReplies: 2Last Post: 31st Jan 2014, 18:35 -
Subtitle position not working...
By djluis48 in forum SubtitleReplies: 2Last Post: 22nd Aug 2013, 10:51 -
subtitle position with aviaddxsubs
By marioval in forum SubtitleReplies: 3Last Post: 27th Feb 2011, 20:15 -
How to move subtitle position in MPC-HC?
By Stealth3si in forum SubtitleReplies: 2Last Post: 14th Feb 2011, 06:46 -
Create Subtitle File from Bitmaps
By otternase in forum SubtitleReplies: 2Last Post: 30th Jul 2010, 13:26
