  1. Hi. is it possible to Rip a 1080i Blu-ray source (29 fps) to 720p (23 fps) for Reduce deinterlace Effect ?
Name:	Time Warp s01e02 Will It Blend BD-Remux 1080p TinyMoviez (WA) (1)-002.mkv_snapshot_00.18_[2015.0.jpg
    to
    Name:  Time.Warp.S01E02.720p.HDTV.x264-DON - Will it Blend.mkv_snapshot_09.57_[2015.05.12_02.14.47].jpg
  2. If the 1080i is 24p with pulldown, yes you can inverse telecine back to the original film frames, downscale to 720p, and reencode.
    May 2014
    Memphis TN, US
    Or you can use a player and TV that handles pulldown and interlace correctly.
    - My sister Ann's brother
  4. Banned
    Oct 2014
    Northern California
    If it is film based you do not need to reduce the resolution to get rid of interlace artifacts all you need to do is inverse telecine.
    If it is video based you can deinterlace your source to 1080p60.
    How did you get the notion that you need to reduce resolution to get rid or reduce interlace effects?
    May 2014
    Memphis TN, US
    1080p 60fps is not BluRay and can't be authored as such. I guess he wants 720p because deinterlacing 1080i isn't valid for BluRay, but 729p/60 is. The O.P. hasn''t given enough info about the source, but if it's telecined it can't be deinterlaced.
  6. thanks. the problem was solved with deinterlace option in Ripbot.
    I tryed two ways in Ripbot. first TFF to 29 , second Inverse Telecine. what's defferent between them ?
    almost same results :
Name:	Time Warp s01e02 Will It Blend BD-Remux 1080p TinyMoviez (WA) Inverse Dont fps (1)-002.mkv_snaps.jpg
Name:	Time Warp s01e02 Will It Blend BD-Remux 1080p TinyMoviez (WA) TFF (11111)-002.mkv_snapshot_00.19.jpg
  7. A film source telecined to 29.97 interlaced frames per second will result in a duplicate frame every 5th frame if you deinterlace to 29.97 fps (leading to several little jerks every second during playback). If you inverse telecine you will remove that duplicate frame and be left with the original 23.976 film frames per second.
    If your source isn't telecined film, but rather real interlaced video, deinterlacing to 29.97 fps will be smoother. Decimating to 23.976 fps will result in a jerky video. Best of all is to smart bob to 59.94 fps -- if your intended playback device supports it.
  8. Thanks jagabo for Description
