  1. So I read and followed what was written here, but I end up getting an error not mentioned in the thread.
    I get:
    usage: livestreamer.exe [OPTIONS] [URL] [STREAM]
    livestreamer.exe: error: unrecognized arguments: best
    off?
    I have no idea why I'm getting that since I change the url and type the code just as the post said to. Ideas?
    The video is at http://www.daisuki.net/anime/watch/M3TheDarkMetal/yMc
  2. Originally Posted by nobodyhome View Post
    I get:
    off?
    hi can you post your code because it works
    livestreamer "hlsvariant://https://bngn-vh.akamaihd.net/i/43383936/35470338/smil/US/00002/816248653689179.smil/master.m3u8?hdnea=st=1431839979~exp=1431840279~acl=/*~hmac=91658a58c843a995fe27346b5afc11ed4d137295092f02c30863f3a17a5ec95f&g=SGUMWMIPDXXK&hdcore=3.2.0" best -o M3-the-dark-metal-01-STARRY-NIGHT.ts
    [cli][info] Found matching plugin stream for URL hlsvariant://https://bngn-vh.akamaihd.net/i/43383936/35470338/smil/US/00002/816248653689179.smil/master.m3u8?hdnea=st=1431839979~exp=1431840279~acl=/*~hmac=91658a58c843a995fe27346b5afc11ed4d137295092f02c30863f3a17a5ec95f&g=SGUMWMIPDXXK&hdcore=3.2.0
    [cli][info] Available streams: 1080p (best), 360p (worst), 480p, 720p
    [cli][info] Opening stream: 1080p (hls)
    [download][..etal-01-STARRY-NIGHT.ts] Written 85.9 MB (4m42s @ 312.8 KB/s
  3. Hmm. Maybe I'm not copying the right url...?
    livestreamer "hlsvarient://https://bngn-vh.akamaihd.net/i/43383936/35470338/smil/US/00002/816248653689179.smil/manifest.m3u8?hdnea=st=1431896716~exp=1431897016~acl=/*~hmac=fc15279eb8795aceebaa1d43f3f85b6acc4ce9eb1766a906913006481a52d447&g=JJKEVCNTYVQS&hdcore=3.2.0" best -o test
    I even used the code you provided and no dice. Did I somehow break livestreamer? If so, how do I go about fixing it?
  4. Originally Posted by nobodyhome View Post
    first hlsvariant and not hlsvarient
    second in green you can't copy the code because expire you need find your own code
    livestreamer "hlsvariant://https://bngn-vh.akamaihd.net/i/43383936/35470338/smil/US/00002/816248653689179.smil/manifest.m3u8?hdnea=st=1431896716~exp=1431897016~acl=/*~hmac=fc15279eb8795aceebaa1d43f3f85b6acc4ce9eb1766a906913006481a52d447&g=JJKEVCNTYVQS&hdcore=3.2.0" best -o test.ts
  5. I feel like an idiot for misspelling, but I put the following in and still got the same issue...
    livestreamer "hlsvariant://https://bngn-vh.akamaihd.net/i/43383936/35470338/smil/US/00002/816248653689179.smil/manifest.m3u8?hdnea=st=1431899653~exp=1431899953~acl=/*~hmac=33ad45d98a22231bf8b887b4a4c54b649da63c421d1d79eceaee51a2da8ac93d&g=IFVTUQNMLYUW&hdcore=3.2.0" best -o test.ts
    EDIT: I finally got it to work. I can't pinpoint what I was doing wrong after you helped me, but it seemed to work after I deleted a .bat file I tried making for a different download and updating livestreamer. I didn't think the .bat file would mess with it.
    Thank you for helping me.
  6. Originally Posted by nobodyhome View Post
    Perhaps it was a question of speed.
    exp=1431899953 exp= means it expires with time
  7. Would you folks happen to know how to resolve this error in livestreamer?
    error: Failed to open output: video.mp4 ([Errno 13] Permission denied: 'video.mp4')
    I think it's a permissions issue, but I can't find anything on how to resolve it. Using Windows.
  8. Originally Posted by leoat12 View Post
    when you run cmd.. run it with admin privileges and then browse to wherever your livestreamer.exe is.. and then try ripping...
