Results 1 to 30 of 34
  1. Excuse me, I would like to ask about encoding the video from Gopro camera.
    The raw file is in mp4 format and It is pretty large so I am trying to encode It into mp4 which x264 or h264 in the most same setting and bitrate but the result which I get is a bit different for the color of the video. P.s. I am using TMPGENC Video mastering work to encode the video and some other programs.
    I have some photos of the detail please take a look and give some of recommended.
    I want to just encode to let it be smaller but keep all quality the same including the color.
    In the photo below is the original before encoding detail.
    image upload no size limit
    or dilect link
    http://postimg.org/delete/64rzwvc4k/
    And This is how I set for encode the video
    adult image hosting
    direct link
    http://s14.postimg.org/glvtcm8v5/5_16_2015_21_30_05.jpg
    upload image online
    image hosting 30 mb
    image hosting 30 mb
    direct link
    http://s14.postimg.org/wiul9c19d/5_16_2015_21_30_14.jpg
    http://s14.postimg.org/d3jtg87z5/5_16_2015_21_30_33.jpg
    And over here is the different of the result between Original and Encoded file
    1. Original video.
    how to screenshot on windows
    Direct link
    http://s14.postimg.org/fz1i0u1cx/5_16_2015_21_32_38.jpg
    2. After Encoded video as you can see the much different in color and contrast
    free photo hosting
    Direct link
    http://s14.postimg.org/e8igzcjtt/kapook_world_748173.jpg
    P.S. I was trying to check if it would look the same if they are on the same bitrate , but what I get is different contrast result
    by the way I would like to resize so I set it down to 12000 kbps before I was trying on the same bitrate as the original one.
    Thank you for your comments
  2. Originally Posted by Sandee W View Post
    If you encode it with the same bitrate, it will be the same filesize.
    Filesize = bitrate * running time
    The other levels issue is because the source video has a full range flag. To keep the same thing you must encode with a full range flag. With x264 you would use:
    --input-range pc --range pc
    I don't use mastering works, but if they have an extra options line you would add that. Or if they have a pulldown menu, you would add that.
    It's not recommended to use full range for video in general, because different software players, renderers and hardware might not play it back properly. Not all players understand or read the flag properly. You should adjust the levels and encode it normal range for it to look the same everywhere
  3. Originally Posted by poisondeathray View Post
    Thank you for your reply , I was trying to check if it would look the same if they are on the same bitrate , but what I get is different contrast result
    Sorry but I don't really understand about level could you give some explaination ?
    below is the advance options
    photo hosting
  4. Banned
    Oct 2014
    Northern California
    Surely you must understand it does not work like that.
    Something's got to give!
    Question for you is what is your problem with the big file?
    After all no bits were harmed in the process.
  5. Originally Posted by newpball View Post
    Thanks for your opinion ! The problem is I have no much space to keep to large file so If I could shrink the file size with keep the acceptable quality (in this case contrast and color) should be fine for me to keep bitrate around 12000 kbps from 45 mbps
    but the question is however I encode it it would always decrease the color of the video ...
  6. Originally Posted by Sandee W View Post
    You're not decreasing the color, you're displaying it differently. In VMW5 use the color correction filter and under YUV there's a dropdown with a CCIR601 Expansion option. If that doesn't fix it you can try increasing the contrast. (Which really will decrease color, but it will look more like what you want.)
    Your real solution though is to get another hard drive if you're going to be shooting a lot of high bitrate, high framerate GoPro footage. As it is you are throwing out half the frames already.
  7. Banned
    Oct 2014
    Northern California
    Perhaps it is a case of large file size phobia.
  8. Member Cornucopia's Avatar
    According to those dialog boxes, your source is 120FPS, and your "intended"? is 60FPS. Given all other aspects being equal, that will cut the size in 1/2.
    And if you intend on being efficient with your allocation of bitrate in the resultant file, it makes much more sense to use CRF/CQ if you can, or 2pass VBR if you can't, rather than CBR.
    So, the 2 items alone, along with judicious choice of max+avg bitrates, could drop your filesize quite a bit.
    However, as newpball has stated, you WILL be losing quality. Whether it's enough for you to notice it (enough) or care is up to you and those settings.
  9. Originally Posted by Cornucopia View Post
    Thanks Scott , I was trying for VBR 2 passed already I could have shrink the size but the result is the same for the color changed.
    Also I did try for 60 fps source, I set it all same setting but what I get is still the same point color changing.
    By the way , thanks for your opinion
  10. Originally Posted by smrpix View Post
    Thanks Smrpix, for your help ! well there is no any way right ? if I would convert it and keep the as same color as the source ?
    I just notice that I set the wrong bitrate in the picture I post in this thread but before I used to try for 60 fps source and I set it all the same setting as the original at 60 fps the same , but just decrease the bitrate to 12000kbs the quality still be ok except the color is drop down in converted video...
    by the way I was trying the another programs as well I was trying gopro stuidio to convert but it's all the same. I can't get the same color as the source...
    I understand about decreasing about quality from original
    my point is just like even I set all the bitrate as same as the source but still I don't get the correct color for converted video...
    I would like to know is there any way to encode and it won't get the wrong color from the original video (I can accept for losing some quality of bitrate)
    I bought 3 1tb external hdd well I don't wanna waste the storage if I can save some of it....
    Anyway , Thank you for your help.
  11. Originally Posted by newpball View Post
    hello again newpball, It's not about large file size phobia haha, I have bought some 1tb external hdd but if I could save some storage I would like to do so. I could accept for decreasing bitrate for little. The point is I would like to know how I can convert with the correct color footage as the original.
    I apologize for any mistakes.
    p.s. also my poor English.
  12. Banned
    Oct 2014
    Northern California
    So why record 120fps if you don't want to store it?
    It's like buying a pizza for takeout and then throwing away half of it because you don't like to carry large boxes home.
  13. Member Cornucopia's Avatar
    As has already been pointed out to you, all those transforms & options aren't the problem. The problem is in how the file+app+vidcard driver+OS+monitor are interpreting your color settings. Something isn't right with one (or, more likely MORE) of those things, and you will have to work out that problem FIRST regardless of your ultimate choice of target bitrate, etc.
    @newpball, capping/shooting 120fps even when storing/editing in 60fps makes plenty of sense if the purpose was to have control over the downconversion algorithm(s)!
  14. Banned
    Oct 2014
    Northern California
    Very true indeed!
    However you can't do that with avisynth
  15. Member Cornucopia's Avatar
    Yes you can (well, I can).
  16. Banned
    Oct 2014
    Northern California
    Interesting.
    You would need something like this:
    You split the video in even and odd frames, then frame double each separate video by reverse motion 'prediction' and then apply a median operation where more weight is given to "matching" frames?
    How do you do it?
  17. Member Cornucopia's Avatar
    I won't tell you exactly, but you can do a Google search on "avisynth motion blur" to get a good example of similar methods.
  18. Originally Posted by Cornucopia View Post
    Thanks again Scott, well let's me ask one more question if it's about the hardware to show the wrong level color of the converted video...
    why I could see the normal level in the original one (sorry for being very stupid for this topic)
    you meant the hardware affect only the video which already converted right ?
  19. First , fill in the details on how you are viewing this ? What software? How did you take the screenshots ? Are you using 1 media player open at 1 time ?
    Usually, the issue with gopro videos is the full range flag and how the other software (either converting or displaying , or both) handles it. Certainly that is what your screenshots suggest
  20. Originally Posted by poisondeathray View Post
    I open two windows of Media player classic to compare to color between the original and converted video then takes the screenshots. And I tried to use another programs such as Gopro studio and winx hd converter to convert but the result was the same. I have got the different color from the original.
  21. You usually cannot use 2 media players at the same time to compare, because the 2nd instance will usually look different because only 1 can use the graphics overlay at a time . Try doing it one at a time - is the difference still there ?
  22. Member Cornucopia's Avatar
    Yes, 2 media player instances will OFTEN show color differences: one uses a different renderer than the other (1st instance has priority in rendering fallback queue).
  23. Originally Posted by poisondeathray View Post
    Yes it still different. Even though I open one window and check for the result.
    Also I tried with another program such VLC too.
    the result is the same as I compared though. : (
    Almost giving up... I can't figure it out except keeping the large raw file.
  24. I've posted the answer in another thread on go pro
    Basically, the go pro files are full range and have a full range flag. This means they use 0-255 levels in Y,U,V , instead of the standard 16-235 for Y , and 16-240 for U and V
    The problem is different software (either decoding, rendering for playback, or converting) don't treat full range files necessarily the same way. Some obey the flag, some ignore it - so some decode it full range, others clamp it, others clip, some convert to RGB with limited range, some use a full range matrix . Even with your original camera files before you convert it, this is true - it can look different in different software
    A) The "best" way is to scale it to "normal range", that way it will look and play the same everywhere
    B) The other way, to decode , encode and flag it full range - that way it will have similar characteristics to the original go pro files (which actually isn't a good thing)
    There might be a small chance that your files are different that the other go pro files, but I really doubt it. If you want to upload a small sample I can verify and check., or if you want to cut a sample and don' t know how to, just ask
  25. Originally Posted by poisondeathray View Post
    Thanks for your help , yes I could give you some of sameple. Well should I upload on youtube or ?
    Another thing is I don't know how to adjust the full flag and level of Y U V in the converter program though...
    Could I send you the sameples in pm ?
  26. Yes you can PM it, but if it's not too personal, you should upload it directly to the public forum (push the upload files/manage attachements buton) so other people can learn from this (ie. Perhaps other gopro users can benefit )
  27. Originally Posted by poisondeathray View Post
    Alright then I will attach here. Well how can I trim the original footage without color changing btw ? cause I need to export it in some program I afraid if It would change the level again.
  28. You can use avidemux to stream copy a segment
    Open the file, set video output to COPY audio output to COPY, output format to MP4 MUXER
    Move the slider to where you want to start then push the "<<" or ">>" button at the bottom of the GUI to jump to a keyframe . Push the "A" button at the bottom of the GUI (not the keyboard) to mark in .
    Repeat for the mark out - Move the slider and push the "<<" or ">>" button then push "B" button of the GUI to mark out
    That section should now be enclosed in a "blue box" on the timeline
    Save the file (ctrl+s), enter filename with extension (e.g. "myfile.mp4")
    It doesn't have to be a large sample, a few seconds is fine
  29. In the meantime, here is a thread with another go pro sample "GOPR1262.MP4" (1080p50) , you can download it directly from post #5
    https://forum.videohelp.com/threads/367549-same-mp4-opened-in-VD-and-avisynth-is-differ...=1#post2349529
    I've attached a re-encode that was decoded full range, encoded full range, and flagged full range, just like the source go pro video (method B). Can you tell me if they both look the same (in terms of levels) on your setup compared to the original "GOPR1262.MP4" ? The re-encoded file is obviously worse in quality (it's 6-7x smaller), I'm just referring to general appearance
    Also one that was scaled to limited range (method A)
    Both used ffmpeg - both should look the same on properly configured playback even though the levels are different. If either or both appear like the original in terms of levels and color (they both should), I can write instructions how to do a batch file with ffmpeg
  30. Originally Posted by poisondeathray View Post
    I apologize for late reply, I checked with those video already
    the full range file seems to be more colorful and contrast
    in opposite the limited range seems similar to the file which I converted , it looks more pale than the full range video.
    The full range file look more like the original video from gopro
