Hello
The USB stick in question will work on PC and Laptop, when conecting to Blu-ray Player (LGBD650) it's not recognising the stick.
The player will play other sticks. Is there a software i can add to stick, then add files and try it that way?
Some Blue-ray players dont recognize NTFS as file system.. Format the USB using the FAT32 FS or better yet ExFat FS..
NTFS is not the problem. The LG BD650 can use both NTFS formatted drives and FAT32 formatted drives.
You could try saving the files on the USB stick to your PC, reformatting the drive, and then copying the files back to the USB drive. -
A lot of USB drives have an autorunned hidden partition (housing backup & encryption software) in addition to the user-data partition. It could be that a simple hardware player is built to only see the 1st (in its mind = ONLY) partition, thus ignoring the subsequent U.D. partition.
Sony blu-ray player via usb says usb device not compatible
By pedroabi in forum Newbie / General discussionsReplies: 4Last Post: 24th Feb 2013, 12:57 -
LG Blu-ray BD350 doesn't recognize a 4 GB USB memory stick
By Vianty in forum DVD & Blu-ray PlayersReplies: 3Last Post: 7th Feb 2013, 12:38 -
Recommendations Please, Blu-ray Player with USB HDD support
By Hollywood_12 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Mar 2012, 17:53 -
converting videos for playback via usb on my Blu Ray player
By TehAnonyMOUSE in forum Newbie / General discussionsReplies: 9Last Post: 22nd Jan 2011, 00:50 -
What can it do if a blu-ray DVD player has a USB port?
By coody in forum DVD & Blu-ray PlayersReplies: 7Last Post: 2nd Sep 2010, 22:12
