When I try to capture DVD's (THAT I OWN) for backup. Only with DVD's I have colored lines across the screen. But with my Satilight and VCR this never happens. Its not my connections either. Do I need a converter or something? I have a Radio Shack Modulator so I can view the DVDs on my old TV. So that converts the format into a viewable picture for my TV. Which is Coxaxile Quility. Soooo any suggestions? Oh Im useing a Apex AD-660-- Which I love!
It's the Apex-660.
I have the same model, with the same problem. Actually, if I record the DVD to a VCR, I sometimes get black/white video only. I'm using a macrovision stripper, so that should not be the problem. When recording in Vdub, it looks like the frame rate is 30 instead of 29.94. Not sure if that has anything to do with it, but there is a non-standard output of the Apex-660. -
Ummm I think I might have found the problem. But not sure I really cant tell. But It seems that if i press the P/N Button on the remote and change it to either ntsc instead of multi. Then it fixes it. But I could be wrong.
VHS capture : red/blue lines
By pastapesto in forum Capturing and VCRReplies: 0Last Post: 24th May 2010, 06:32 -
Silver lines during video capture
By noelsoasis in forum Capturing and VCRReplies: 6Last Post: 27th Apr 2009, 18:52 -
Capture Settings / Weird lines in final product
By BooBerry in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 23Last Post: 26th Jan 2009, 12:14 -
Will sending video from my TV through my vcr/dvd player get rid of lines?
By Darkstraw in forum Newbie / General discussionsReplies: 7Last Post: 15th Aug 2008, 00:47 -
Vertical Lines Appearing On Capture
By XBucklawX in forum Capturing and VCRReplies: 0Last Post: 26th Jun 2007, 12:11
