Here is my code
If using the latest stable build of Handbrake, It's ok.Code:-i input -o output --decomb --detelecine --crop 0:0:0:0 -e x264 --x264-preset=slower --vfr -x me_range=24:aq-mode=4:level=4.0 -E copy -v2
but, if using any nightly build, Handbrake execute to encode with auto cropping.
I tried to add some options:
-w, -h, --loose-crop, --strict-anamorphic, --keep-display-aspect
and I also tried GUI. got same result.
do you have any idea?
Ask in the handbrake forum, https://forum.handbrake.fr/viewforum.php?f=4
Thank you for your replying.
I have tried to register in that forum. but, no activation mail in mailbox and spambox, resending activation mail doesn't work for me. they doesn't allow to re-register with an already in use id or e-mail.
This is why I ask in here.
I'll go on my way. -
Okey...they don't want any feedback....
But it sounds like a bug.
You can check https://trac.handbrake.fr/search?q=crop and see what cropping changes they have made. I can't see any huge changes.
handbrake unwanted cropping
By ricmetal in forum Newbie / General discussionsReplies: 2Last Post: 5th Apr 2015, 04:34 -
Custom Cropping in Handbrake - width unchanged?
By Spiny Norman in forum Video ConversionReplies: 5Last Post: 22nd Jan 2015, 13:36 -
Handbrake svn6361 (nightly build) does not stretch the video anymore
By Tetsuro in forum Video ConversionReplies: 5Last Post: 5th Sep 2014, 15:01 -
RE: custom-build advice needed
By Senex in forum ComputerReplies: 22Last Post: 25th Oct 2012, 19:48 -
Handbrake cropping too much
By ryangarfield in forum Blu-ray RippingReplies: 2Last Post: 14th Jun 2011, 17:42
