Hi there,
I am currently in the process of developing an application that would require to capability of watching 3 separate clips at once.
My vision is to upload 3 separate video clips into a program that could combine them into one single file, then open that file in a player that could play the three clips at once in a split screen style format.
In short
- Click video.file
- Opens player
- Begins to play 3 video clips simultaneously on three separate screens in the same window.
Are there any programs or players that can do this so that i could control all three clips separately? Meaning, could i pause one while the other two played? or go full screen to just one of the clips?
Hopefully I have explained my requirements properly.
If anyone knows of any such methods or programs your help is greatly appreciated!
THANK YOU!![]()
Any NLE should do that.....
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Yes, or a simple Avisynth script.
And this app can do a lot more:
http://hammultiplayer.org/
And it is freeware!
Split and save mp4 into smaller clips?
By itm2 in forum EditingReplies: 2Last Post: 18th Jan 2015, 08:15 -
Merging two video takes into one or replacing green screen with pictures
By BadDisciple in forum EditingReplies: 4Last Post: 11th Mar 2014, 07:20 -
Any advice on how to split a large AVI into smaller clips easily?
By Bluelude1 in forum Capturing and VCRReplies: 11Last Post: 19th Jun 2011, 11:55 -
Problem merging video clips and suggestion on best tool?
By nerys in forum EditingReplies: 1Last Post: 18th May 2011, 00:41 -
merging two video clips together + sync-ing? (with examples!)
By arthritis in forum Newbie / General discussionsReplies: 2Last Post: 18th Sep 2010, 06:23
