Hello,
I'd like to ask a couple of questions about .ts files.
I want to save a local copy of a radio programme on the www. The first step is to download all the .ts files. The site uses JWPlayer to stream audio contents, with each .ts containing 10 seconds of contents.
I notice that the sizes of the downloaded .ts are not uniform. The "normal" size is 87420B each, but the size of every 5th one is only 87232B. For example, a sequence of files named from "file_3.ts" to "file_15.ts", the sizes of "file_4.ts", "file_9.ts" and "file_14.ts" are 87232B but the rest are 87420B large.
Is this a normal phenomenon ?
Next I concatenate the .ts files to a single .mp3 file using FFmpeg. The resultant .mp3 is then played with FFplay.
I notice that when a "jump" or noise is heard in the playback, some error lines appear :
In my understanding, this should indicate some imperfection in the file. It would be ideal to check the entire .mp3 with FFplay, but obviously not an efficient way.Code:> Duration: 00:06:40.32, start: 0.016531, bitrate: 64 kb/s > Stream #0:0: Audio: mp3, 32000 Hz, stereo, s16p, 64 kb/s > Metadata: > encoder : Lavf > [mp3 @ 02fc7ac0] overread, skip -5 enddists: -3 -3 > [mp3 @ 02fc7ac0] overread, skip -5 enddists: -4 -4 > 12.37 M-A: 0.000 fd= 0 aq= 2KB vq= 0KB sq= 0B f=0/0
I wonder if there is a tool for such integrity check without real-time playback ?
	Thanks for the suggestion. Yes, the site does use .m3u8 playlists.
 However, my internet connection is not stable such that FFmpeg often dies prematurely.
 Indeed the downloaded .ts seem to be intact, but I'm curious about the pattern of file sizes.
 On the other hand, it's disappointing to hear that there is no fast tool for integrity checking.
 It means I have to listen the entire .mp3 and hope that nothing has gone wrong near the end.
  Newbie Conversion questions: combine multiple .m2ts filesBy Deku Scrub in forum Blu-ray RippingReplies: 10Last Post: 30th Aug 2013, 19:58
  Newbie questions re: RAM upgrade and undeletable filesBy ElJimador in forum Newbie / General discussionsReplies: 8Last Post: 28th Jan 2013, 22:38
  Hard-subbing .ass Subtitle Files to .mkv Files to be Playable on HDTVBy Sansui in forum SubtitleReplies: 4Last Post: 18th Nov 2012, 13:21
  How to convert DV avi files to DVD ready MPG files with Win7 powershell.By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 17:42
  Few questions regarding LCD tv... that will lead to more questions :)By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
 Quote Visit Homepage
				Visit Homepage
