So, I'm searching for an easy-to-deal-with tool which would help me author a DVD with 2,3 or more episodes of my favorite TV series!
I have already tried ConvertXToDVD and I'm not satisfied with it, so any other suggestion would be greatly appreciated! Thank you!
EDIT: The files are MKV and I was hoping to insert some subtitles as well.![]()
What is wrong with convertxtodvd?
But you can try avstodvd and dvdstyler. -
ConvertXToDVD often results in twitchy video, I don't know why! Maybe I'm setting it up in the wrong way (could it be because I'm not using the 2 pass encoding???)...
Chances are 99 in 100 that your "MKV" sources are miles away from being DVD compliant without some induistrial-strength reprocessing. Can't say much to help, as MKV is a container, not a format. It can support video having widely different structures and codecs, whereas "DVD" has rather narrow limitations. I went into this thread thinking from its title that it was about "authoring", but it's really about converting and re-encoding. I guess a lot of people out there still don't know the difference.
- My sister Ann's brother
Free and Simple DVD Authoring Program
By Todd Sauve in forum Authoring (DVD)Replies: 11Last Post: 9th Aug 2012, 03:19 -
Simplest DVD authoring program?
By paristideu in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2011, 12:08 -
Can anyone recommend a DVD authoring program that will fulfill my needs?
By smythotech in forum Authoring (DVD)Replies: 5Last Post: 17th Aug 2011, 18:37 -
DVD authoring program for mac
By BIFFtheSTIFF in forum MacReplies: 2Last Post: 25th Apr 2011, 03:23 -
DVD authoring program that will add Macrovision
By Nolonemo in forum Authoring (VCD/SVCD)Replies: 19Last Post: 31st Oct 2010, 04:26
