  1. Hello,
    I've just downloaded an avi-file and its colours are very much of pink and green and very little of blue.
    It's not that it's not watchable, but still... Sound quality is rather good.
    Is there any possibility of getting rid of this wrong colours while converting it to MPEG?
    Or is there another way?
    Thanks, Basileus
  2. You wouldn't happen to have the angelpotion codec installed, would you?
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  3. I don't think so. How can I see if it's installed?
    I've installed the Nimo Codec Pack and recently DiX 5.0.1.
