  1. Hi
    If anyone still remembers DOS?
    I can't save the echo command with two variables. How does it properly save?
    echo %audio%t%%
    Feb 2004
    Australia
    What is it your doing ?
    Via batch script or similar in dos prompt (arrow up should return last dos prompt used)
    You can get an idea from this
  3. DECEASED
    Jun 2009
    Heaven
    Originally Posted by Jamaika View Post
    Hi
    Yes, I do. It was a 16-bit operating system which was reduced to a mere bootloader for Windows 95, 98 and M.E.
    In other words, the image below is not a "DOS prompt" at all
  4. Thanks for the reply.
    I am trying to write my own converter mkv to mp4 with the possibility of transferring attachments. I used DOS, long time, and hence problems. I should learn C ++, but it's too difficult for me. I have Windows 8.1.
    set w=0
    set z=0
    set /p srt= < %file%_format_audio.txt
    set str=%str:,/=,und/%
    echo.%srt%> %file%_format_audio_mod.txt
    del %file%_format_audio.txt
    :label2
    set /a id1=1+%w%
    set /a id2=2+%w%
    set /a id3=3+%w%
    set /a id4=4+%w%
    set /a t=1+%z%
    echo %id1% %id2% %id3% %id4%
    for /f "tokens=%id1%,%id2%,%id3%,%id4% delims=,/" %%a in (%file%_format_audio_mod.txt) do (
    echo %%a %%b %%c %%d
    if [%%b]==[AAC] set codec2=aac
    if [%%b]==[AC-3] set codec2=ac3
    set /a m=%%a-1
    set id=%%a
    set lang=%%c
    set ida=%%d
    ffmpeg -y -loglevel warning -i "%file%" -f %codec2% -map 0:%m% -c:a copy -vn -sn -dn -map_chapters -1 -map_metadata -1 %file%%t%.%codec2%
    if [%codec2%]==[aac] set audio%t%=-add "%file%%t%.%codec2%:sbr:lang=%lang%:trackID=%id%:name=(Audio %t%)"
    set audio%t%=-add "%file%%t%.%codec2%:lang=%lang%:trackID=%id%:name=(Audio %t%)"
    if [%codec2%]==[] set audio%t%=""
    echo %audio%t%%
    set w=3
    set z=1
    if [%ida%]==[%id4%] goto label2
  5. not sure what you want to do, if you want to print variable "audio" and "t" it should be:
    echo %audio%%t%
    or with some space between those:
    echo %audio% %t%
  6. I want to be able to display the values of "audio1" to "audio100", where %t% is the second value from 1 to 100.
    I don't want two separate values.
    Originally Posted by _Al_
    echo %audio%%t%
    echo %audio% %t%
    Sep 2012
    Australia
    CALL echo %%audio%t%%%
    or
    SetLocal EnableDelayedExapansion
    echo !audio%t%!
    EndLocal
  8. Thanks. Finally properly displayed.
