Guys, I have probably the most simple and stupid also problem EVER:
I need Mediainfo custom output. However it does NOT include the extension of file name, so the output looks like this:
File : The Power of Nightmares.cd1
Format : AVI at 1659 Kbps
Codec : DivX 5 at 1541 Kbps
Resolution : 640 x 480 (1.333) at %fps% fps
Audio : MPEG-1 Audio layer 3 at 96.0 Kbps
Bitrate : 2 channels, 44.1 KHz
As you can see, the most important information - the extension of the file!!! - is missing. I use %FileName% as parameter. I cannot seems to find the parameter that give the file WITH THE EXTENSION. VERY flustrating, that I cannot find any form of manual with listed the options for Mediainf.
And I certanly do NOT want the filename WITH FULL PATH, that is different option %CompleteName% and the damn software stoped showing the FSP AGAIN. Sigh.
Please help.
PS. after restart it started to showing fps again, but... that it is.
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config -
Solved. The missing template option is this: .%FileExtension%
Result is satisfactory:
File : The Power of Nightmares.cd1.avi
Format : AVI at 1 659 Kbps
Codec : MPEG-4 Visual at 1 541 Kbps
Resolution : 640 x 480 (1.333) at 25.000 fps
Audio : MPEG Audio at 96.0 Kbps
PS: most helpfull was this note from autor:
"Note: I am aware there is a big lack of documentation about templates, it was a prototype and I did not have the time to finish it, documentation is on the ToDo-list when I have some free time. in the meanwhile, there are some examples there."
http://sourceforge.net/p/mediainfo/code/HEAD/tree/MediaInfo/trunk/Source/Resource/Plugin/Custom/
...and the linked examples. Hoooray, problem solved!"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config
AVI video file with otrkey extension
By vidblue in forum Newbie / General discussionsReplies: 1Last Post: 14th Mar 2014, 12:50 -
Video file with no file extension - how to tell type???
By will7370 in forum Video ConversionReplies: 2Last Post: 13th Oct 2012, 05:52 -
What is a r4m and r4s file extension?
By ravens4life in forum AudioReplies: 1Last Post: 29th Feb 2012, 20:35 -
WMV missing Menu section using MediaInfo
By Modify_inc in forum Video ConversionReplies: 3Last Post: 4th Mar 2011, 23:11 -
When and how did the four digit file extension enter the MS world?
By yoda313 in forum ComputerReplies: 4Last Post: 21st May 2010, 00:07
