Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
    May 2007
    I know Adobe After Effects will, but are there other titles? Is it a very simple process, or do you need to have a certain skill to accomplish this feat? Thanks!
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Pretty much all NLE's allow you to chroma-key out colors or use masks to cover-up or show through. You can also use Cinegobs keyer. The difficulty depends on the source clip and your skill level. Like everything else in video and photography, it's an art that also requires skill.
  3. If the background is more or less a uniform color, it is relative simple.
    If the background is a real-life shot, it takes a feat!
    Stopping development until someone save me from poverty or get me out of Hong Kong...
    Twitter @MaverickTse
