Hey all a couple of users from another thread of mine recommended bdrebuilder to use and I gave it a try and its a great program. Im putting mp4s directly onto bd-r without encoding, The burns come out great just have a little issue. When I put one mp4 on a disc it loads up fine on my ps3 and ps4. But when I put multiple mp4s on disc it makes a generic quick menu and when I try to play that on my ps3 or ps4 it doesn't load. It just gets stuck on a black screen. I tried the disc in my stand alone blu ray player and it works fine. I thought that was kind of weird so why could that be? When i just repack the mp4 using bdrebuilder to make the file structure and not encode is it making a blu ray disc that will work in most or all blu ray players?
Results 1 to 13 of 13
Have you tried click on next/forward/play on the ps3/ps4 "remote control"? Nothing happens?
Can you disable the menu in bdrebuilder? THen try that.
You could also try bdtoavchd and/or rebox.net and see if you can remux several mp4s to blu-ray without reconverting. -
Yeah I tired all that it just stays on the black screen when it has the menu on ps3/4. Now when theres only one video on a blu ray without menu it works fine in the ps3/4 very weird.
I have no idea if theres a way to disable the menu.
Ill just stick with bdrebuilder cause its so easy to use. I just have one question. When I play the disc with multiple videos and the menu in my stand alone blu ray player it works perfect. When putting a mp4 on blu ray using bdrebuilder what does it actually do? I know it doesn't re encode but does it just make the blu ray file structure so the players read it. Are they fully compatible and compliant blu rays that will work in most players? -
Most MP4's floating about on the net are nowhere near compliant to Blu-ray specifications. If you are making your own, you can encode to Blu-ray specs easily enough.
But in my experience, BD Rebuilder will re-encode MP4 files to be compliant when making a compilation Blu-ray. Have you watched it in action? It starts by re-encoding AAC normally seen in MP4 to AC3. Then it makes a psudeo Blu-ray structure so it can import the video. Then it starts re-encoding the video streams. If it was just repackaging the video into a Blu-ray, the way you might do with tsMuxeR, it would take only a couple of minutes to do this process. -
Yeah heres the log for one of my video files.
[11:13:54] Importing: RAW_JANUARY_1998
- [11:14:09] Importing video file: (1 of 4)
- Preparing MP4 for processing...
- Collecting audio/video streams from source...
- Converting audio, Track #2, AAC to AC3...
- Integrating into pseudo-BD structure...
Then at [11:22:42] it started the next video. Yeah I didn't download theses from the net though. I ripped these from the wwe network myself a 4500k stream. And heres the media info on the video.
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : 27
Duration : 1h 32mn
Bit rate mode : Variable
Bit rate : 4 465 Kbps
Maximum bit rate : 5 500 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.162
Stream size : 2.88 GiB (92%) -
720p at 29.97fps is not strictly compliant to Blu-ray specs. There could be any number of other things that aren't compliant also.
You only provided a small bit of the log. It converts the audio and makes a psuedo Blu-ray structure for each individual entry, then proceeds with re-encoding the video streams. Then it re-muxes and builds the Blu-ray output.
As I said, just putting it into another container format would take very little time. If BD Rebuilder is taking an hour or more for 3 or 4 videos, then it is re-encoding. I just made one with four MP4 files as input. Original size of the input files was 1.2gb. Output was 5gb and it took more than an hour to process. So yes, the program will re-encode if necessary.
BD Rebuilder makes use of tsMuxeR to make Blu-ray structure. But tsMuxeR by itself will not discriminate on what is compliant and what is not. It will put virtually anything into a Blu-ray, but that doesn't mean that it will play in a stand alone player. And tsMuxeR will not make menus. -
Hmm well idk it doesn't say anything about encoding in the log just audio converting. Heres the full log from a import I just did.
[00:01:11] Importing: RAW_MARCH_1998
- [00:01:46] Importing video file: (1 of 5)
- [00:11:07] Importing video file: (2 of 5)
- [00:19:42] Importing video file: (3 of 5)
- [00:28:24] Importing video file: (4 of 5)
- [00:38:18] Importing video file: (5 of 5)
- [00:47:20] Creating Quick-Play Menu...
- Encoding menu background...
- Building menu structure...
[00:47:28] Video import completed successfully.
Heres media info before the import
General
Complete name : C:\Users\user\Desktop\Raw March 1998\Raw Is War 3-2-98.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 2.82 GiB
Duration : 1h 30mn
Overall bit rate : 4 445 Kbps
Writing application : Lavf55.32.101
Video
Format : AVC
Codec ID : avc1
Duration : 1h 30mn
Bit rate : 4 343 Kbps
Height : 720 pixels
Frame rate mode : Constant
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.157
Stream size : 2.76 GiB (98%)
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 30mn
Bit rate : 93.5 Kbps
Maximum bit rate : 96.0 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 60.8 MiB (2%)
Text
Format : EIA-608
Muxing mode : SCTE 128 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Duration : 1h 30mn
Bit rate mode : Constant
Stream size : 0.00 Byte (0%)
Encoded stream size : 0.00 Byte (0%)
And heres the m2ts file bdrebuilder made
General
Complete name : C:\Users\user\Desktop\IMPORTS\RAW_MARCH_1998\BDMV\ STREAM\00001.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 3.06 GiB
Duration : 1h 30mn
Overall bit rate : 4 824 Kbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 1h 30mn
Bit rate : 4 432 Kbps
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.160
Stream size : 2.81 GiB (92%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : 129
Duration : 1h 30mn
Bit rate : 192 Kbps
Bit depth : 16 bits
Delay relative to video : -21ms
Stream size : 125 MiB (4%)
What I think it does is just tells it to resize the picture. Because in the pseudo folder theres a file called pinfo and in that file has the following
[VideoAdjust]
00001=.LanczosResize(1920,1080)
00002=.LanczosResize(1920,1080)
00003=.LanczosResize(1920,1080)
00004=.LanczosResize(1920,1080)
00005=.LanczosResize(1920,1080) -
That still doesn't look like the full log. BD Rebuilder isn't resizing however, you've still got 720p video with 29.97 frame rate.
By comparison, here is the one I made:
Code:[21:41:35] Importing: SEASON_3 - [21:42:02] Importing video file: (1 of 4) - Preparing MP4 for processing... - Collecting audio/video streams from source... - Converting audio, Track #2, AAC to AC3... - Integrating into pseudo-BD structure... - [21:42:27] Importing video file: (2 of 4) - Preparing MP4 for processing... - Collecting audio/video streams from source... - Converting audio, Track #2, AAC to AC3... - Integrating into pseudo-BD structure... - [21:42:50] Importing video file: (3 of 4) - Preparing MP4 for processing... - Collecting audio/video streams from source... - Converting audio, Track #2, AAC to AC3... - Integrating into pseudo-BD structure... - [21:43:13] Importing video file: (4 of 4) - Preparing MP4 for processing... - Collecting audio/video streams from source... - Converting audio, Track #1, AAC to AC3... - Integrating into pseudo-BD structure... - [21:43:36] Creating Quick-Play Menu... - Encoding menu background... - Building menu structure... [21:43:42] Video import completed successfully. ---------------------- [05/11/15] BD Rebuilder v0.50.06 [21:45:00] Source: SEASON_3 - Input BD size: 1.42 GB - Approximate total content: [02:53:15.760] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - Quick-Play Reauthoring mode enabled - Quality: High Quality (Default), CRF - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [21:45:00] PHASE ONE, Encoding - [21:45:00] Processing: VID_00001 (1 of 4) - [21:45:00] Extracting A/V streams [VID_00001] - [21:45:10] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 23.976fps, 63,092 frames - [21:45:10] Performing CRF Prediction... - Analyzing 11.00 10.50 10.25 10.13 10.06 10.03 10.02 [10.02] - [21:45:58] Encoding using constant rate factor. - [21:57:42] Video Encode complete - [21:57:42] Processing audio tracks - Track 4352 (und): Keeping original audio - [21:57:42] Multiplexing M2TS - [21:57:55] Processing: VID_00002 (2 of 4) - [21:57:55] Extracting A/V streams [VID_00002] - [21:58:05] Reencoding video [VID_00002] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 23.976fps, 62,494 frames - [21:58:05] Performing CRF Prediction... - Analyzing 11.00 10.50 10.25 10.13 10.06 10.03 10.02 [10.02] - [21:59:04] Encoding using constant rate factor. - [22:11:13] Video Encode complete - [22:11:13] Processing audio tracks - Track 4352 (und): Keeping original audio - [22:11:13] Multiplexing M2TS - [22:11:27] Processing: VID_00003 (3 of 4) - [22:11:27] Extracting A/V streams [VID_00003] - [22:11:37] Reencoding video [VID_00003] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 23.976fps, 61,808 frames - [22:11:37] Performing CRF Prediction... - Analyzing 11.00 10.50 10.25 10.13 10.06 10.03 10.02 [10.02] - [22:12:38] Encoding using constant rate factor. - [22:24:37] Video Encode complete - [22:24:37] Processing audio tracks - Track 4352 (und): Keeping original audio - [22:24:37] Multiplexing M2TS - [22:24:51] Processing: VID_00004 (4 of 4) - [22:24:51] Extracting A/V streams [VID_00004] - [22:25:01] Reencoding video [VID_00004] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 23.976fps, 61,855 frames - [22:25:01] Performing CRF Prediction... - Analyzing 11.00 10.50 10.25 10.13 10.06 10.03 10.02 [10.02] - [22:26:09] Encoding using constant rate factor. - [22:40:36] Video Encode complete - [22:40:36] Processing audio tracks - Track 4352 (und): Keeping original audio - [22:40:36] Multiplexing M2TS [22:40:51]PHASE ONE complete [22:40:51]PHASE TWO - Rebuild Started - [22:40:51] Rebuilding BD file Structure - [22:40:51] Creating Quick-Play Menu... - Encoding menu background... - Building menu structure... [22:40:56] - Encode and Rebuild complete [22:40:56] JOB: SEASON_3 finished.
Oh ok I think I know what im doing wrong. After the import is finished im not clicking the back up button. But why have it do all that? After the import is done it burns successful on disk and plays in my blu ray player.
But its not working in all your players. Your PS3 and PS4 don't like the preliminary output and frankly, I'm surprised it works anywhere. Try making a complete backup and test in those players. It is far more likely to be compliant to Blu-ray requirements.
Im gonna try and see what happens. When I import one file to disk it works in the ps3/4. Ill update once done.
BDRebuilder Cropping Problem
By GreyDeath in forum Blu-ray RippingReplies: 10Last Post: 3rd Nov 2013, 19:08 -
Ripping with BDRebuilder
By tarzan54 in forum Blu-ray RippingReplies: 7Last Post: 26th Jun 2012, 20:58 -
Problem with BDrebuilder
By tarzan54 in forum Blu-ray RippingReplies: 10Last Post: 20th Jan 2012, 19:45 -
BDrebuilder stops halfway, help please
By volam1 in forum Blu-ray RippingReplies: 16Last Post: 24th Oct 2011, 18:41 -
PowerDVD 7.3 and new BDRebuilder
By dharper40 in forum Blu-ray RippingReplies: 4Last Post: 7th Sep 2011, 07:23
