SOLVED - see post # 3
Hi all. I've been away hammering on a project my boss enlisted me in. Anyway. I have a mdb database i'm working on and in one aspect of it i am utilize a grid to show and set a few values though mainly boolean. They are true/false values in a check box to make flagging the rows easier. But now i need to reset them all to no value (blank box), or false. I added a button to the form. Note, this is not the actual ms access IDE, it is a standalone short program to test something out really quick for him. I'm looking for an SQL version if possible. I can feed that into the backend code elsewhere.
I think it can be done in an update query but i'm not sure. I usually use ms access for that through the query section and then through { menu\View\SQL View } obtain the SQL text part. I know, cheating, but I can't remember everything in this beast.
Thank you very much in advance.
fields and values:
Code:prodID YesNo Notes ------ ----- ----- 1 true don't run 2 true don't run 3 false 4 true look both ways 5 true its supper man 6 false 7 true don't run 8 true bake me some pizza 9 true home made pizza dough 10 true mini pizza
I think I have SQL script working:
Code:UPDATE tbl SET tbl.yesno = False;
Well, it almost works. while it complete the resting to all FALSE, I also get an error message:
'Current provider does not support returning multiple recordsets from a single execution.'
I'll figure it out.Last edited by vhelp; 7th May 2015 at 23:46.
SOLVED
In the windows application I was building (using delphi 7) I was using the wrong windows non-visual components to do the job.
Also, I enhanced the SQL string to only update any records who's boolean value were check-marked or True, super quick performance.
Code:UPDATE tbl SET tbl.yesno=false WHERE tbl.yesno=true
No reason whatsoever why you first code would not do the job - SQL would simply ignore the rows that would not require updating. I doubt that the issue was the SQL but, as you said, the program itself since the new code simply replicates the result of the first.
Can't get picture to fill 16x9 screen
By blitzen in forum Video ConversionReplies: 4Last Post: 13th Feb 2015, 09:27 -
live invert values
By artsrtx in forum Capturing and VCRReplies: 3Last Post: 30th Jun 2014, 16:25 -
ConvertXTtoDVD won't fill a DVD-5
By Somebla in forum Authoring (DVD)Replies: 37Last Post: 5th Jun 2011, 16:14 -
Pinnacle is leaving gaps, that i cant fill..........
By jorisss in forum Newbie / General discussionsReplies: 0Last Post: 9th Dec 2010, 13:28 -
An out-of-bounds memory access (access violation)
By rjc7394 in forum Video ConversionReplies: 0Last Post: 17th Jun 2010, 17:42
