Hey and good day.. I use Handbrake 0.10.1.6962 64bit. I have been using it to recode some MKV files that when played back through my Oplay streamer the fast forward function would stick and never be able to play again.
So, I have been converting them to mp4/m4v with great success until now.. I have experimented using the Quality setting and found that 16 with a slow decode rate gave me a good size file and good quality.
I have changed nothing and yet now every time I recode the same size and source of MKV file the quality setting is changed to 20.. Even though the slider is at 16, I am getting file sizes 1/3 of what I was getting.. Previous recode size was about 600 meg, now 200. I have re-tried this at least 7 or 8 times now and still keep getting the same problem.. I know it is not the source file problem because I had recoded them before and got quality (17) results, but wanted to try to improve the quality of them a bit so I re-ran them at "16" setting as I had a bunch of the others...
When I check the log on these weird results sure enough it says "20" as the quality output setting..
I have uninstalled the program and reinstalled and I am still getting the same results. Any ideas and help greatly appreciated.. thank you
Try upgrade to latest nightly beta
https://handbrake.fr/nightly.php
Or switch to VidCoder (based on Handbrake). I like it better. -
Thank you for the tip.. I downloaded it and used the "file size" option and had great success.. I still scratchin my head over why HB went on the fritz.. so strange.. No matter what i did I could not get it to mux a file with the same results I had just hours before.. from 600mb files down to 220mb and with apparent quality issues as well. haven't tried it since because Vidcoder works so reliably.. so thanks again.. I guess until I have a reason to leave Vidcoder I won't be messing with HB for a while..
What is your main reasons for using Vidcoder??
thanks again..
stringpickin
Setting for Xvid on Older Handbrake
By Johnbil in forum DVD RippingReplies: 0Last Post: 20th May 2014, 14:18 -
Question about Handbrake's 'Constant Quality' setting
By Ronaldinho in forum Newbie / General discussionsReplies: 10Last Post: 8th Jun 2013, 03:55 -
Problem setting up Handbrake
By PhoneMatt in forum Video ConversionReplies: 7Last Post: 15th Mar 2011, 12:29 -
what would the best setting for me for Handbrake ? plz answer
By FaisalKhan in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2011, 09:38 -
Best h.264 setting for optimal size/quality with handbrake.
By frickfrock99 in forum Newbie / General discussionsReplies: 4Last Post: 1st Oct 2010, 03:09
