Hi,
I'm using Handbrake to convert 1080p video to 720p.
Conversion seems fine, but length of video goes from 1 hour 43 min. to 1 hour 42 min. in the output file. That causes small errors in the audio.
I use "same framerate as source" but "variable"
Should I use "constant" to avoid this weird problem??![]()
99% of the time, VFR (Variable Frame rate) causes more problems than it cures!
Yes, you should use constant. Will it fix it? Hard to tell, depends on the source and on other settings.
Problem with Handbrake
By Cygnus111 in forum DVD RippingReplies: 6Last Post: 30th Jun 2014, 13:26 -
Handbrake problem, please help.
By PonyoBellanote in forum Video ConversionReplies: 9Last Post: 8th Dec 2013, 13:59 -
Handbrake: VOB to MKV - Framerate cut in half
By Track in forum Video ConversionReplies: 20Last Post: 18th Sep 2013, 04:47 -
Handbrake Framerate
By JackDanielZ in forum Capturing and VCRReplies: 4Last Post: 26th Jul 2012, 00:36 -
Every video I make with Handbrake mkv has framerate of 90000 & wont convert
By Onceler2 in forum Video ConversionReplies: 7Last Post: 12th Sep 2011, 10:26
