Just wondering is there anything simple out there that can allow me to join two video files together. I don't plan to do any cutting or editing just placing one video file after another. I have been using aviutl but that takes up to an hour to get the job done. Anything maybe less than half an hour or so?
	If the video files have exact same properties(resolution, frame rate, codecs, etc) can you join without converting using for example avidemux, file->open, file->append, video->copy, audio->copy, save as a new mkv/mp4/avi. Or join mkv files with mkvmergegui. Or ts/mts files with tsmuxer.
 Or else must you reconvert (and it takes much longer like aviutl).Last edited by Baldrick; 6th May 2015 at 04:08.
	up to an hour?
 What are the resolution of your videos and how long are they?
 If you are on a Core i5 or i7, you can use the included QSVEnc encoder and get a 5~10X speedup
 (Quality is not as good as x264 however.)Stopping development until someone save me from poverty or get me out of Hong Kong...
 Twitter @MaverickTse
	The smart editing thing (for anything except AVI) has quite a lot of limitations.
 If you use it on some TV-broadcast recordings, it is almost certain that the resultant file will be corrupted/invalid.
 Just search "Smart editing" on this forum and you will find loads of threads on it (and you shall notice its problem.)Stopping development until someone save me from poverty or get me out of Hong Kong...
	Video to Video does more than join videos and it is a very good free program.
  Joining video files - Your favorite application?By indijay in forum Newbie / General discussionsReplies: 4Last Post: 27th Jun 2013, 15:54
  Joining two different sized video filesBy nominalgrevious in forum Newbie / General discussionsReplies: 8Last Post: 7th Mar 2012, 17:38
  Joining video files in mkvmergeBy Zee530 in forum Newbie / General discussionsReplies: 0Last Post: 13th Oct 2011, 15:29
  Joining Blu ray video files.By whatyaar in forum Authoring (Blu-ray)Replies: 3Last Post: 20th May 2011, 05:22
  Joining 2 video files- too complex for Virtualdub?By miketheratguy in forum Video ConversionReplies: 23Last Post: 16th Aug 2010, 17:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
