I've got some 10bit recordings and I need to convert them to 8bit. I'm familiar with Avisynth but I don't know how to do that. Does anybody know how please and can you provide a scipt to do the job. Thanks
I can use x264 encoder but the resulting picture looks weird like it's brighter than before.
Just avisynth can't convert. Use any converter like vidcoder or command line software like ffmpeg, x264 encoder.
Please, again with more details...
You "got some 10bit recordings" ... means, they have been encoded with x264 in Main10 or High10 profile, which your consumer player (model?) doesn't support? Or what exactly? MediaInfo analysis?
And they have to be encoded with x264 in (8 bit) Main or High profile to make them compatible with consumer players?
So, well, the basic solution simple: Just recode with any AviSynth or ffmpeg based converter; if both 8 and 10 bit of x264 are supported, select x264 with 8 bit as encoder. To avoid too much loss of quality, do not attempt to compress to the same bitrate, rather expect to need more.
But "the resulting picture looks weird like it's brighter than before" is a different issue. It may be related to colorimetry parameters (e.g. Rec601 vs. Rec709, TV/PC range, etc.).
MPC HC: 32-bit or 64-bit on Windows 7 64-bit
By flashandpan007 in forum Software PlayingReplies: 20Last Post: 22nd Jul 2016, 09:22 -
How Can I convert a 24-bit W64 to 16-bit FLAC?
By eddman in forum Newbie / General discussionsReplies: 13Last Post: 27th Feb 2015, 10:36 -
Virtual Dub: How to convert video from avi 24 bit to avi 9 bit sample size?
By Dilshaad in forum Video ConversionReplies: 10Last Post: 4th Mar 2014, 11:02 -
Convert 10-Bit MKV to 8-Bit
By wingfat in forum Video ConversionReplies: 8Last Post: 2nd May 2013, 20:44 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40
