Hi all,
I have a .wmv file that is 14 min long according to MediaInfo, but only will play the first 5 minutes regardless of what players I use. I have tried converting it to other formats using asfbin, Freemake, etc, but only the first 5 minutes get converted. Windows Movie Maker won't even open the file. What is wrong and how do I fix this? What software can I use to get the full 14 min?
Thank you in advance for your help!
Have you tried re-muxing/re-indexing it with WM utilities (WM File editor, WM Stream Editor, etc)? What does ASFView show?
Scott -
Even with Mplayer and VLC
Apparently you've got a file whichWindows Movie Maker won't even open the file. What is wrong and how do I fix this?
a) is the result of two (or more) other WMVs that were joined improperly,
b) went corrupted, or
c) both of the above
MAYBE it can fixed by remuxing through ffmpeg.
Another possibility: VirtualDub in its Direct Stream Copy mode, which will give you an AVI file though
(which can be remuxed to ASF again with ffmpeg itself, OR the ancient vidtoasf.exe, for example).
MOV is damaged; repair software says it is not a movie file?
By pennypuncher in forum Newbie / General discussionsReplies: 7Last Post: 5th May 2015, 20:06 -
How to repair a damaged 3gpp files?
By chilliran in forum AudioReplies: 6Last Post: 19th Jan 2014, 05:02 -
Repair wmv and asf files
By Creed92 in forum Video ConversionReplies: 17Last Post: 28th Dec 2013, 09:53 -
Repair restored Video files (avi, wmv)
By chromx in forum RestorationReplies: 9Last Post: 19th Dec 2013, 14:35 -
MOV files damaged (but play fine in VLC) -repair how?
By tigrr in forum Video ConversionReplies: 9Last Post: 4th Feb 2011, 16:34
