Hello,
I'm trying to reproduce a file with this mediainfo but it starts to blink and to pixel a lot:
General
Complete name : D:\cam\20150502082910_20150502085010.avc
Format : AVC
File size : 200 MiB
Video
Format : AVC
Format profile : Baseline@L3
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Width : 704 pixels
Height : 480 pixels
Display aspect ratio : 3:2
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
My settings are: options, internal filters, transform filters and checked h264/avc; Thread for multi-threading 4; hardware acceleration divxa2 (native).
I tried opening the files in avidemux but popup "Cannot find a demuxer for file".
What can I do?
It's an elementary video stream. Most media players require you to put it in a container in order to play it back . Although some like ffplay and VLC should be able to play it as is
You can put it into a MKV container with MKVToolNix for example. Or MP4 container with YAMB beta 2, or MyMP4BoxGUI. Or a transport stream with TSMuxer
Sometimes the footage is encrypted if this is from a recording device , or security cam that sort of thing -and you would need the proprietary key or software to play it
MPC HC: 32-bit or 64-bit on Windows 7 64-bit
By flashandpan007 in forum Software PlayingReplies: 20Last Post: 22nd Jul 2016, 10:22 -
MPC-HC will not play anything except mp4 container
By DUDERANCH in forum Newbie / General discussionsReplies: 4Last Post: 27th Jul 2013, 21:17 -
Can't play downloaded AVC/H.264 videos
By gumbygum in forum Software PlayingReplies: 14Last Post: 12th May 2011, 10:59 -
64-bit real media plugin/codec for MPC-HC?
By cheerful in forum Software PlayingReplies: 0Last Post: 3rd Oct 2010, 08:01 -
How do I play this AVC file downloaded with replay media catcher
By no_alone in forum Newbie / General discussionsReplies: 2Last Post: 25th Aug 2010, 20:18
