  1. Is there a way to convert DTS 7.1 to WAV 7.1, so I can convert it with dbpoweramp to aac-fdk codec? I have Bigasoft Total Video Converter to convert 5.1 audio to 5.1 flac, but I have a movie that has 7.1ch, but Bigasoft Total video converter flac and wav supports 5.1 so, I was wondering if its possible to have 7.1 wav or flac either one will work! I just need a software that will convert dts 7.1 to wav/flac 7.1 intact!
    Sep 2012
    Australia
    EAC3To?
    7.1 MUST be either DTS-MA or DTS-HRA since plain old DTS can only have 5.1 channels (which would be why your converter will only do 5.1 - it's only converting the core and not the HD extensions.)
    (DTS-MA taken from a Blu Ray has a DTS core, which players that don't support HD extensions can play. You need a program that can decode the HD extensions as well to get the other two channels and lossless audio, (or increased bitrate in the case of HRA.))
