Where should saturation/hue/etc... be on the scale numerically?
It depends on the source, and to your own preferences to a small degree. If you post a short sample maybe some suggestions can be offered. The only real important thing, for me, is not to blow out the whites or crush the blacks. If you do, they can't be fixed later on. Most of the rest can.
There is no single 'best' setting for the proc amp controls. -
Certainly it should be tweaked depending on what's coming in, but I am looking for baseline settings to use as a starting reference. Do you use this device? Do you have baseline numbers?
Also, does VirtualDub have a built-in histogram?? -
VDub (which is what you're using, right?) has defaults. Try those. I've never found defaults to be good enough, though.
The Hauppauge? No, I have a different USB capture device. I've capped plenty through VDub, though.Do you use this device?
Nope. Look, do some 'practice' short captures and have a look with a histogram or something. Adjust the settings and make some more short caps. When you have everything the way you like, do the 'real' capture.Do you have baseline numbers?
It has a capture histogram, yes, but I do my histogram and other checks in AviSynth scripts. VDub has HSV Adjust, a Levels filter, a brightness/contrast filter, and some others either built in or downloadable. Those would be for post-capture processing. Others know more about them than I.Also, does VirtualDub have a built-in histogram?? -
VirtualDub capture mode: Video -> Histogram. But you have to switch to Video -> Preview instead of Video -> Overlay.
capture card with proc-amp capabilities
By smartel in forum Newbie / General discussionsReplies: 17Last Post: 25th Mar 2013, 22:27 -
Hauppauge USB live 2 capturing with virtualdub and lagarith
By rudolf016 in forum Capturing and VCRReplies: 13Last Post: 14th Apr 2012, 10:14 -
Using VirtualDub's "capture filter" proc amp
By sanlyn in forum Capturing and VCRReplies: 3Last Post: 31st Jan 2012, 07:13 -
Hauppauge 1212 HD PVR & VirtualDub
By MakiManPR in forum Capturing and VCRReplies: 3Last Post: 23rd Oct 2011, 11:31 -
Proc amp before TBC?
By JVRaines in forum Capturing and VCRReplies: 0Last Post: 30th Mar 2011, 16:26
