I have a large MKV file
I can't burn it to disk since NERO VIDEO 14 wont accept the file. Thought it might have been too long but that's not the issue.
Tried to convert the file using format factory ( returns err0000001).
The file plays in VLC player but if I try to convert it to another format VLC player fails---as in just quits and crashes.
Tried to 'repair' the MKV file by using Meteorite.exe. It creates a new file that has the same failure modes.
Have split the 3plus hour MKV into 2 and repeated all above without any change.
Can I perhaps save/convert the file that VLC player plays and capture the result that way?
Any other Ideas?
OK ill try that--thanks
I figured if it played the file it should be able to convert it--perhaps not
vlc player wont play avi
By natty in forum Newbie / General discussionsReplies: 7Last Post: 15th Dec 2013, 10:49 -
mkv plays in VLC but not MPC
By shun in forum Video ConversionReplies: 3Last Post: 7th Apr 2013, 07:24 -
'MP4 has no usable track' yet plays in VLC Media Player
By JuliaR in forum Newbie / General discussionsReplies: 6Last Post: 10th Mar 2012, 17:57 -
DVD plays differently on VLC vs other software/hardware?
By PartyRambo in forum Authoring (DVD)Replies: 5Last Post: 31st Oct 2011, 03:29 -
Help with VLC player convert feature!!
By dannyzero in forum Newbie / General discussionsReplies: 0Last Post: 27th Aug 2010, 12:57
