Hey,
Perhaps a noob question but..
So far I have been using tsMuxerGUI to create my files into bluray ISOs that I can then burn off, and this has been fine for 1 long video, but I now want to have multiple videos on the disk. I tried to add multiple files into tsMuxerGUI but it just created one video with multiple video tracks.
Is there any easy way I can drag and drop multiple files in tsMuxerGUI and it will create a Bluray with videos that would play one after each other?
	You have to join rather than add the streams -- and they have to be compatible with each other.
	Aww thats a shame...
 So how does it work on Retail Blurays of TV shows with multiple EPs?
 Is that really just one long video with Chapters and Menus?
	Did you use the append button in tsmuxer? If you use open it will create one video with multiple track.
	I mean the join button. (append was in mkvmergegui).
 Edit: Okey. I missed smrpix answer.
	I see.... No i didnt.
 I guess I'll do that, what is the best software to achieve what I need?
	you can use Bd-rebuilder and select ''play items sequentially'' in import/quick-play settings . take only the temp folder that it created. no need to re-encode if your files are bluray compliant.
  FFMPEG - How to record multiple RTMP streams into multiple filesBy wwwmaster2k in forum Capturing and VCRReplies: 1Last Post: 11th Jul 2014, 13:51
  Authoring for multiple seasons of a TV showBy no cigar in forum Authoring (Blu-ray)Replies: 3Last Post: 2nd Sep 2012, 16:14
  Remove multiple tracks from multiple MKV filesBy accoutabc in forum Video ConversionReplies: 3Last Post: 7th Aug 2011, 12:50
  Re problems editing in tmpgenc authoring works 4 using multiple video filesBy ukcalibrauk8 in forum Authoring (DVD)Replies: 4Last Post: 2nd Jul 2011, 03:25
  Merging/Converting Multiple M2TS files to MKV With Multiple Audio TracksBy Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
