I couldn't tell from the past posts whether you used MI or not (no readouts, or reference to it till now).
PLCreator sounds good, but as a solution it will suffer the same fate as all other playlist methods: only some players support playlists. And in this app's case, it only outputs PLS and M3U formats.
Good luck,
Results 31 to 34 of 34
As of July 2018, do most MP3 players now support embedded chapters, or should I just use a .CUE file for each and every MP3 podcast as a safer approach to jump to locations in a given file ?
Thank you. -
Would there be a simple solution to this if it didn't have to be free?
All this need/discussion seems to suggest that someone could design a solution that they would deserve to be paid for.
no? -
It hasn't been suggested before (and I hope that the O.P. found a working solution in the last three years otherwise we are all damned and doomed !) but VLC Media Player can play directly from a ZIP/RAR archive (possibly other types as well) containing media files, and navigate between those files as if they were chapters of a single file. Other software players may have that capability. The archive ought to be created with the “store only” setting (although VLC can deal with compressed files, it could cause playback issues and/or increase CPU/memory usage).
TMPGenc DVD au. 3: Lengthy audio as menu item?
By Spiny Norman in forum Authoring (DVD)Replies: 14Last Post: 26th Oct 2014, 07:02 -
App to Identify Video Formats from Lengthy Lists
By box-turtle in forum Newbie / General discussionsReplies: 6Last Post: 2nd Sep 2014, 17:13 -
Divide a DL into Dvd R disk
By RBCC in forum EditingReplies: 2Last Post: 22nd May 2013, 02:32 -
Difficult splitting lengthy video (please help)
By hellfire45 in forum Video ConversionReplies: 7Last Post: 20th Feb 2011, 04:25 -
How to auto divide DVD into editable clips?
By yamahaalex37 in forum Video ConversionReplies: 5Last Post: 18th Jan 2011, 01:59
