Sorry if this has been posted elsewhere:
Are you still getting errors even when you burn at low speeds, and on several different machines with Imgburn and DVD Decrypter? Puzzled?
Yes you can get write/verify errors because of the following:
1. Bad Media - try a different brand.
2. Burner Firmware - either become corrupted or needs an upgrade.
3. Maybe bug in the programme - unlikely as both seem stable, but check anyway.
4. Could be a sign that your burner is failing.
However, before you try any of these try this:
If like me you are in the habit of burning .iso files kept on an external hard drive - plug the hard drive directly into your computer - i.e not through a USB hub. I created a lot of coasters before I realised that might be the reason.....
You might also like to review this thread:
https://forum.videohelp.com/threads/369898-Imgburn-I-O-Errors-fix-worked-for-me
Closed Thread
Imgburn I/O Errors - 'fix' - worked for me....
By bahjan in forum Newbie / General discussionsReplies: 5Last Post: 3rd May 2015, 13:00 -
Burn errors with ImgBurn
By davidimcintosh in forum Newbie / General discussionsReplies: 21Last Post: 15th Dec 2013, 21:24 -
Sony Optiarc DVD RW Drive writes but verify errors???
By bahjan in forum DVD & Blu-ray WritersReplies: 7Last Post: 6th Jan 2012, 09:33 -
I/O errors using ImgBurn and DVD Decrypter
By jcsdmd in forum Newbie / General discussionsReplies: 16Last Post: 27th Aug 2011, 15:58 -
Decrypter to Shrink to Imgburn?
By visionman in forum DVD RippingReplies: 3Last Post: 19th Jan 2011, 13:06
