I have a MPEG-TS file that isn't getting recognised in mkvmerge (does not contain any tracks error) and similar error in avidemux. The media is there as it plays fine in VLC.
Here is the mediaInfo details
General
Complete name : X:\Users\user\Videos\Service_ CH4_5_.ts
Format : MPEG-TS
File size : 628 MiB
Duration : 20mn 8s
Overall bit rate : 4 357 Kbps
Video
Menu ID : 2 (0x2)
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=4, N=32
Codec ID : 27
Duration : 20mn 6s
Bit rate : 3 883 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.075
Stream size : 559 MiB (89%)
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Color range : Limited
Audio
Menu ID : 2 (0x2)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Duration : 20mn 8s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : -456ms
Stream size : 36.9 MiB (6%)
Language : English
Menu
Menu ID : 2 (0x2)
Duration : 20mn 8s
List : 102 (0x66) (AVC) / 202 (0xCA) (MPEG Audio, English)
Language : / English
Maximum bit rate : 200000000
You can try tsmuxer. Demux all tracks and add in mkvmergegui.
Perhaps yout ts file does not start cleanly on a ts packet with magic packet start byte ?0x88? and these programs cannot handle reading into the stream to synchronize to the next sequence of 188 byte spaced start bytes? You could look in a hex editor at the very first byte and if it is not that value this could be your problem. VLC is likely smart enough to know that not all recording devices start the ts file cleanly? Good luck and let us know.
Hi,
I have a very similar problem again, so instead of starting a new thread I thought it would be more appropriate to place it here.
So I have another TS file that I'm having problems playing. None of my video tools can read the video track, only the audio track (both audio and video play OK in VLC). It is a recording of a live broadcast and the same error occurs for each file created. I wonder if there is a problem reading the header?
In Avidemux:
In TSSniper: (see now the video info is clearly visible in the left column on PID 512, yet only the audio track on PID 4112 recognised in the timeline)
mediaInfo:
Code:General ID : 1 (0x1) Overall bit rate mode : Constant Overall bit rate : 24.8 Mbps Network name : Net 1 Video ID : 512 (0x200) Menu ID : 1 (0x1) Format : MPEG Video Format version : Version 2 Format profile : 4:2:2@High Format settings, BVOP : No Format settings, Matrix : Custom Format settings, picture st : Field Codec ID : 2 Duration : 2mn 3s Bit rate mode : Variable Bit rate : 23.2 Mbps Maximum bit rate : 23.8 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:2 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.448 Time code of first frame : 03:42:36:16 Time code source : Group of pictures header GOP, Open/Closed : Open Stream size : 341 MiB (93%) Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 4112 (0x1010) Menu ID : 1 (0x1) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Codec ID : 3 Duration : 2mn 3s Bit rate mode : Constant Bit rate : 320 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Delay relative to video : -28ms Stream size : 4.70 MiB (1%) Language : English Menu ID : 256 (0x100) Menu ID : 1 (0x1) Duration : 2mn 3s List : 512 (0x200) (MPEG Video) / 4112 (0x1010) (MPEG Audio, English) Language : / English Service name : Service 01 Service provider : Net 1 Service type : digital television Maximum bit rate : 24786000
If vlc can read it properly, then ffmpeg should be able to process it . You can try a GUI such as xmediarecode if you are trying to edit /cut
Or you might be able to re-wrap it with ffmpeg into another container so other programs can read it properly
External Harddrive Not Recognised
By Teac23 in forum ComputerReplies: 13Last Post: 20th Jun 2014, 22:44 -
new SSD drive not recognised
By DB83 in forum ComputerReplies: 22Last Post: 31st Jan 2014, 05:48 -
Blackmagic Intensity Pro - NTSC Captured File Not Recognised at Interlaced?
By kauri in forum Capturing and VCRReplies: 22Last Post: 22nd Nov 2011, 12:21 -
Cedocida DV Codec - 16:9 not recognised?
By BertRito in forum Newbie / General discussionsReplies: 30Last Post: 11th Jul 2010, 20:50 -
Floppy Drive Not Recognised
By spliffy in forum ComputerReplies: 38Last Post: 26th May 2010, 02:45
