I am looking to Author some SD Interlaced footage onto a Blu-ray and i notice the option have it encode progressive. My big thing is, i don't want to see the lines caused by some interlaced footage. Should i Deinterlace the footage and then put it through the progressive encoding of TMPGENC, or i should i leave the footage interlaced and then have it go through the progressive encoding of TMPGENC. Also, Should i be deinterlacing at all? Thoughts Please.
If it's SD interlaced content , then leave it interlaced . Your TV setup can handle it and will deinterlace it - you won't see "lines"
I won't even try to guess what kind of footage it is, except for you saying that it's interlaced. If it's telecined, you can't deinterlace anyway.
Which TMPGEnc product are you using?
Standard definition "regulation" BluRay isn't progressive. It's either interlaced or telecined.
The general BD specs: https://www.videohelp.com/hd#tech
The details on BD encoding for HD-MPEG and h264: http://forum.doom9.org/showthread.php?t=154533
BluRay/AVCHD can be encoded with either MPEG or h264.- My sister Ann's brother -
Short version: the answer is still the same - keep it interlaced. You won't see "lines".
Even if the content is progressive (e.g. a theatrical movie at 24p), you need to encode it interlaced, because of BD restrictions (the signal has to be interlaced). There are a SD progressive encoding variant that is flagged interlaced, and a pulldown variant, but those are not supported universally by all players. The "safest" thing to do is encode it interlaced . Note those are options for progressive CONTENT, that output an interlaced signal (it's analogous to DVD)
If you have interlaced CONTENT (e.g. a home video), then you have to encode it interlaced. You could deinterlace it, but to keep the smooth motion you need to double rate deinterlace to 59.94p. That is illegal for SD resolution. Only 720p59.94 is allowed. So you would have to upscale it. Or you could single rate deinterlace it and throw away 1/2 the data to 29.97p, but that needs to be encoded interlaced, or encoded progressive with the "fake" interlace flag. (Usually nobody wants to throw away 1/2 the data) -
The alternative is to properly deinterlace it and play it with a HTPC, that way you avoid all those "brilliant and well thought out" BD and DVD standards.
Deinterlace and upscale with a good deinterlacer like the QTGMC deinterlacing AviSynth script and use SplineResize for upscaling!
While quite a few people claim that LCD TVs are masters at deinterlacing and upscaling I would advice you to take that with a grain of salt. Many people seem to be motivated to immediately downplay any shortcomings related to DVDs and Blu-ray disks and their respective standards.
And some others seem ready to downplay (deflect) their shortcomings in understanding of standards.
Very often one obtains better quality to leave it alone til the end (display) than to convert and re-encode. Plus, you keep it more universally compatible.
Determining if video is progressive or interlaced
By SameSelf in forum Video ConversionReplies: 10Last Post: 9th Mar 2015, 03:13 -
Interlaced scanning, progressive video?
By hello_hello in forum Video ConversionReplies: 23Last Post: 4th Nov 2014, 17:38 -
Why are there interlaced Blu-Ray formats?
By brassplyer in forum EditingReplies: 20Last Post: 8th Dec 2012, 09:24 -
interlaced and progressive in same video. how to make only progressive.
By OmniShadow in forum Newbie / General discussionsReplies: 32Last Post: 18th Sep 2012, 23:44 -
Blu-ray Weird Interlaced Problem
By daamxlaws in forum Video ConversionReplies: 15Last Post: 10th Sep 2012, 23:05
