I've got a silly problem that I'm hoping someone can explain or fix for me. I converted a capture from AVI to MPG2 in TMPGE. Upon completion the file size (in Windows explorer) is just over 3 GB. WHen I try to create a project in DVDit PE with it, it states that my project size is 4 GB ??? As well if I change the audio settings from PCM to AC3 and then select "update" next to project size window the size does not change. Any clues as to what I'm doing wrong? Thanks
Mark
Try de-muxing the audio and video into seperate files and putting them into DVDit PE that way. I think it will then be able to calculate the size of the audio mor accuratley.
Originally Posted by bugster
Mark -
demux the audio with vurtualdub from the avi. Save as PCM (uncompressed) at 48Khz sample rate. Then imprt this wav file into DVDit PE. Dont forget to select convert to Dolby AC3 if your video file is over 3 Gigs as a PCM file is large and may not fit otherwise
Mark -
That update bug is a known problem with DVDit when you use AC3 sound files. They claim to have fixed it in the latest patch, but my version of DVDit PE is working just fine and dandy... if it ain't broke don't fix it, I figure.
--=Major
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 17:08 -
subtitles with DVDit 6 PRO
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2010, 13:51 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 01:08 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 12:49 -
sony vegas project size
By chidoug in forum Newbie / General discussionsReplies: 4Last Post: 7th Mar 2008, 23:22
