Results 1 to 16 of 16
    May 2015
    montreal
    Hello. Message below. Thanks for any assist.
    System.IO.FileNotFoundException: Retrieving the COM class factory for component with CLSID {56FDF344-FD6D-11D0-958A-006097C9A090} failed due to the following error: 8007007e The specified module could not be found. (Exception from HRESULT: 0x8007007E).
    at System.RuntimeTypeHandle.CreateInstance(RuntimeTyp e type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
    at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
    at System.RuntimeType.CreateInstanceDefaultCtor(Boole an publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
    at System.Activator.CreateInstance(Type type, Boolean nonPublic)
    at System.Activator.CreateInstance(Type type)
    at System.Windows.Window.ApplyTaskbarItemInfo()
    at System.Windows.Window.WindowFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
    at System.Windows.Interop.HwndSource.PublicHooksFilte rMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
    at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
    at MS.Win32.HwndSubclass.DispatcherCallbackOperation( Object o)
    at System.Windows.Threading.ExceptionWrapper.Internal RealCall(Delegate callback, Object args, Int32 numArgs)
    at MS.Internal.Threading.ExceptionFilterHelper.TryCat chWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
  2. DECEASED
    Jun 2009
    Heaven
    Installation error message
    Installation OF WHAT, sir
    The less you say, the less the others may help you.
    May 2015
    montreal
    hmmm, thought this was a forum dedicated to VidCoder. Missunderstanding related to the link where I downloaded the software.
    VidCoder is the program. I understand it uses the Handbreak engine.
    What information can I provide that would help you analyze the issue?
    Admin: please feel free to add "VidCoder" to my subject line for clarity.
    You can edit your thread title by clicking on edit and go advanced on your first post.
    Have you installed .net 4.0?
    http://www.microsoft.com/en-us/download/details.aspx?id=24872
    May 2015
    montreal
    Hello. Not at home atthe moment, but I beleive when I checked it was 4.0.3 or 4.1.3 in the registry. I have recently installed 4.5 but oddly didnt see it listed in the registry when I checked. I will verify when I get home.
    I should ask: does it need that exact version or will any higher version suffice
    Thx
    May 2015
    montreal
    .net 4.0.30319 is in fact installed.
    For some reason my windows updated to 4.5 successfully, but does not show this in the registry unless it is buried somewhere else.
    Win 7 64bit pro by the way.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    Latest vidcoder 2.1 beta? Portable version?
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Does handrake work?
    May 2015
    montreal
    Version = 1.5.31.0 (last non-beta version)
    I chose the 64 bit version
    Handbrake works, but recently started dropping audio on some conversions made with the VLC capture. Which is one reason I started looking at alternatives. Some posters indicated that VidCoder worked when Handbreak was giving them trouble.
    Handbreak however gives an error at startup as well. I will run it and see if I can copy the error message.
    Handbreak error:
    A file appears to be missing.
    Try re-installing Microsoft .NET Framework 4.0
    Im racking my brain trying to think of any other info that would be useful to you folks, but I am a complete rookie when it comes to video conversion or encoding.
  10. Third line tells you to reinstall NET Framework 4. So, try to do that. Uninstall current NET Framework and install it again.
    May 2015
    montreal
    Jeeze, life moving too fast I red that too quickly and missed the "re". Not enough hours in the day.
    Will give that a shot. Hopefully installing ontop works as I didnt find .NET in add remove programs.
    thx
    May 2015
    montreal
    I get the following message.
    Details
    Same or higher version of .NET Framework 4 Client Profile has already been installed on this computer.
    The .NET I have in add/remove programs is 4.5. Does Handbreak not work properly with newer versions?
  13. Yes, HB works with NET 4.5.
    May 2015
    montreal
    Okay, so I have installed 4.5 after receiving the errors, thus the issue does not appear to be only a .NET framework issue.
    May 2015
    montreal
    Any other information I could provide to help trouble shoot this? Or could someone recommend a conversion software that does as nice a conversion as Handbreak? I used SuperC in the past but got very poor results converting my webcam records from VLC.
    Thx
    May 2011
    Dont give up on VidCoder just yet..Uninstall any previous versions and make sure you uninstall any settings files if it prompts you to,then download the 2.2 beta portable version 64bit or x86 if your using a 32bit system put it in a folder of your choosing then clic the.exe and be patient the first time its loading..It works fine.I have never installed VidCoder and I have always updated to a newer beta portable without fail and it is my encoder of choice...Good Luck
