I´m thinking about buying an external drive to burn back-ups of my data on blu ray M-disc.
The problem is that my computer is very old , it´s a Pentium Intel (R) 4 2.40 Ghz, 512 RAM.
Is there any external Blu ray drive compatible, either current or out of the market? I´m only interested in burning data to M-discs not movies, so playback is not needed.
Thank you in advance
You'll need USB 2.0 at a minimum. The LG BE14NU40 external drive should work with M discs, though the last I heard, 4x was maximum speed.
A PC that old (2002?) may only have USB 1.0. If that is the case, you would need to install an add-on card for USB 2.0. If it is a laptop, that may not be possible.
The other problem could be finding compatible drivers that will allow the BD RW drive to work with your OS if this PC runs a version of windows that predates Windows XP
If the PC has USB 2.0 and runs Windows XP, LG BE14NU40 recommended by Kerry56 is a good choice since it has its own power supply and does not draw power from the PC. -
Yes, I have USB 2.0 (4 ports) and my OS is windows XP service pack 3 but LG BE14NU40 requires 2GB of RAM according to this: http://www.manualslib.com/manual/423065/Lg-Be14nu40.html?page=6
Looking to buy an External Blu-Ray Drive for a desktop PC
By KyleMadrid in forum Newbie / General discussionsReplies: 9Last Post: 16th Apr 2013, 02:36 -
connecting external hard drive to blu ray player then accessing data off it
By julie_152 in forum DVD & Blu-ray PlayersReplies: 36Last Post: 24th Sep 2012, 07:44 -
Blu-Ray Player that plays .avi (and other) with external hard drive?
By RushMaster in forum DVD & Blu-ray PlayersReplies: 8Last Post: 26th Dec 2011, 11:51 -
Playing my external hard drive from LG blu ray???
By Shadowx22 in forum Newbie / General discussionsReplies: 9Last Post: 17th Oct 2011, 06:21 -
I have a question about connecting an external hard drive to Blu-ray
By shalevagr in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Aug 2011, 19:38
