What kind of subtitles are you using? If they are image bitmap subtitles you can't reposition them without extracting, OCRing, reformatting and remuxing.
If it is pre-rendered there is not much you can do.
I'd say not just a 21th century thing, I think pre-rendered subtitles really belong to this period:
But that's just my opinion I am sure stuffy old video engineers will disagree and call pre-rendered subtitling some brilliant technology that still should be used, while I just "don't understand the fine subtleties".
Subtitle position not working...
By djluis48 in forum SubtitleReplies: 2Last Post: 22nd Aug 2013, 09:51 -
Opening MPC-HC at a specific position
By mkvideo in forum Newbie / General discussionsReplies: 4Last Post: 13th Aug 2013, 16:50 -
MPC-BE: how to display datacode (PGS-Subtitle) like in MPC-HC
By flashandpan007 in forum Software PlayingReplies: 0Last Post: 29th Apr 2013, 13:14 -
How to move subtitle position in MPC-HC?
By Stealth3si in forum SubtitleReplies: 2Last Post: 14th Feb 2011, 05:46 -
Subtitle not working in MPC HC
By majid_aryaee in forum SubtitleReplies: 6Last Post: 13th Oct 2010, 10:43
