Hi guys,
I want to upgrade my pc to 4k resolution.
I heard that 4k at 30Hz is not very good, so what are my options for a video card if i want a smooth 60Hz 4096x2160 desktop ?
I'm not gaming.
My motherboard is a Gigabytes P67X-UD3-B3.
thank you and sorry for my english.
For starters you need a card that has DisplayPort.
HDMI 2.0 does support 4k/60P as well but caveat emptor, your colors may be crippled due to HDCP. -
thanks newpball.
so it looks like the GTX 650 Ti BOOST is the cheapest 4k video card with a displayport . Am i right? it's very confusing. -
Note that both HDMI & DP will/should require HDCP 2.2 compatibility (not out yet) on BOTH ends of the chain (source, sink) in order to display 4k/UHD 60p copyrighted work. If it's your own internal/private/personal stuff, or if it is your desktop/apps screen, that won't matter.
Yeah, that card looks to be the lowest of the nvidia line to support both 4k/60p and DP.
ScottLast edited by Cornucopia; 30th Apr 2015 at 19:02.
1280x1024@60Hz to 1080p30 or 1080i60
By luckyo in forum Capturing and VCRReplies: 7Last Post: 3rd Jul 2014, 14:37 -
60Hz video with ~30Hz chroma
By Brad in forum RestorationReplies: 6Last Post: 29th Mar 2013, 14:58 -
cheapest software to make watermark and blur on video
By moniia in forum Newbie / General discussionsReplies: 0Last Post: 17th Feb 2011, 09:03 -
Cheapest way to record video programs from time warner cale USA/NYC
By marcolisi in forum Capturing and VCRReplies: 2Last Post: 4th Aug 2010, 14:53 -
Need to capture in 60hz frequency
By Teryolilio in forum Capturing and VCRReplies: 18Last Post: 21st May 2010, 11:58
