Hi guys,
https://www.youtube.com/watch?v=sFu5qXMuaJU
On 0:39 there is this sound effect. What's it called? I'm making this video and I want my audio to stop with that effect. So the song in my video needs to stop suddenly when you hear that effect. Does someone know how to do is? I use Sony Vegas. Thx
A number of elements:
Synth Bass drop
Power Drums (drum kit+gated reverb) hits
Synth bed/hit that is played in reverse for ramp at begin, sharp "attack" at end
Synth lead ringing loop w/clipped endings (possibly reverse clip also)
Way in the background: low synth bed using FM modulation + BP filter following envelope, possibly looped
There are likely more elements, but that's what I can gather from a first/second listen.
No "effects", just electronic music. Vegas can EDIT some of this (loops, reverse, maybe pitch), but it cannot create this. You need a DAW that can use either samples or midi with virtual instruments.
If you have to ask, you're not ready to tackle a job like this.
How is this effect called?
By Sweetamber in forum EditingReplies: 26Last Post: 7th Jan 2013, 03:44 -
What is this called and how do I fix it?
By jarlaxle in forum Newbie / General discussionsReplies: 5Last Post: 28th Feb 2012, 04:08 -
Audio Effect help needed (Pinnacle Studio 11)
By JohnP in forum EditingReplies: 0Last Post: 5th Apr 2011, 05:44 -
What is it called and how to fix it? (from an old video)
By namphong0612 in forum EditingReplies: 5Last Post: 18th Sep 2010, 20:19 -
convert swf to anything that can be called from powerpoint
By flannob in forum Newbie / General discussionsReplies: 2Last Post: 17th Sep 2010, 06:24
