I currently have a MythTV PC setup that records from my HDHomeRUN PRIME in an MPG2 format from my cable company.
For the longest time, I cut the MPGs with MPG2Cut2 and then threw them in to ffmpeg's libx264.
My problem is that the HD recordings are too big and I would prefer to encode directly to MP4 with ffmpeg and then cut with AviDemux or something similar.
Would there really be any difference in cutting afterwards vs before?
MPG2Cut2 sometimes has me leaving small slivers of commercials due to keyframe cutting but I don't want to have more with AViDemux.
Will I be able to cut in the same places or just have ffmpeg allow me to leave keyframes in the same areas?
I would normally do that, but my MythTV Linux Headless PC is 4 cores and can encode via ffmpeg command line way faster than my Desktop Quad Core can even with ffmpeg.
For some reason my Linux PC can encode like 3-4 times faster than my PC but being headless I can't really control AviDemux to cut files very efficiently.
I was hoping to do a massive convert to reclaim space and then cut later. -
FFmpeg's MP4 is not AAC?
By Djard in forum AudioReplies: 8Last Post: 20th Oct 2014, 20:53 -
Ts to Mp4 FFmpeg Issue
By PolarWindzTranscode in forum Video ConversionReplies: 2Last Post: 2nd Feb 2014, 06:30 -
Converting everything to mp4 using ffmpeg
By euphonic in forum Video ConversionReplies: 1Last Post: 13th May 2011, 08:53 -
ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!
By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 05:53 -
Help with FFmpeg .TS to .mp4
By ViM in forum Video ConversionReplies: 2Last Post: 15th Nov 2010, 11:39
