Hi, I have this video I'd like to clean up if possible. It at least needs some anti-aliasing, not sure if sharpening and/or denoising is possible without losing too much detail. This script doesn't get rid of it, should I use another filter? Or isn't it aliasing what I'm seeing? It's noticable in the first few seconds and near the end
DirectShowSource("alias.ts") ### input
AssumeFPS(30000,1001) ### 30>30000/10001
Undot() ### denoising
Cnr2() ### more denoising
daa3mod() ### anti-aliasing
I included the first 17 seconds in the attachments, I would hugely appreciate it if someone knew how to fix this. I don't know a lot about AviSynth filters
	That is actually a decent SD source. There is nothing particularly wrong with that apart from the standard SD usual suspects like edge 'enhancement', blurry motion probably due to a blurry deinterlace and slightly 'funny' colors. Compression is good!
 What you notice in the beginning is simply the result of limited resolution, but that is a given for SD.
 Processing will probably mess up more than it improves things.
	That video was inadequately deinterlaced. It will be very hard to reduce the remaining artifacts.
  vlc anti-aliasingBy shernoam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2014, 16:55
  Virtualdub anti aliasingBy simonrule in forum EditingReplies: 2Last Post: 31st Jul 2013, 13:14
  No anti-aliasing for DVD menu textBy fvisagie in forum Authoring (DVD)Replies: 5Last Post: 12th Feb 2013, 02:36
  Please suggest good AviSynth Anti-Aliasing & Rainbow Remover scriptsBy VideoFanatic in forum RestorationReplies: 0Last Post: 30th Nov 2011, 07:54
  anti-aliasingBy anthell in forum RestorationReplies: 4Last Post: 7th May 2010, 23:08
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
