  1. when i chose ts file 2 open it 2 creat avs script 2 crop black borders , the following error msg appears , although it was working good before
    i need another perfect app for doing crop black borders , or just force this bad megui 2 make scripts
    i updated the k-lite codec pack mega n megui but no use
    i tried past versions of megui n no use
    i tried avisource after converting it 2 avi but at last it doesnt work
    also used Avidemux , many programs n tools like camtasia n Sony Vegas Pro 10 for crop it ,, but all r discusting , or am a big looser at using them
    plz plz plz, NO TIME 4 TRYING THEN FAIL , just need a succesful way
    my pc = win. xp . 32 sp3 \ hp desktop \ lga processor \ 1 gb ram \ vga built in i think
  2. Banned
    Oct 2014
    Northern California
    Trying to run an NLE with 1GB of ram is going to be an epic failure.
  3. Originally Posted by newpball View Post
    rendering is ok mostly , but the last Result with black bars or borders
    so what is the solution of my mentioned proplem
    n i success at cropping too many times before = by megui with the same pc or machine
  4. thnk god , proplem is solved , i updated AviSynth program 2 the latest version
    i thaught - before this - that it can be updated by updating k lite mega codecs , but the loosers doesnt do it
