How do i convert 5 channel audio for vcd (44100hz)virtual dub won't do it
please help
Are you talking about a .ac3 file ?? If you are, them check if both the video and audio timelenght matches. If it does, just force it onto tmpgenc and it will convert the audio into a mpg file for you. Works all the time for me and the audio is always in sync with the video.
if divx contain 5 channel
i use TMPEG 2.53 to set Directshow Multimedia file reader to higher priority
convert my avi to mp2 -
can't find an option to convert avi audio to mp2 in tmpg enc
am i missing something?
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 22:46 -
Convert Iron Man BD to MP4 using RipBot - Audio Channel Issue
By csilvest in forum Blu-ray RippingReplies: 5Last Post: 27th Jan 2009, 11:25 -
Best way to convert DVD-r w/ 1 channel audio to mono?
By progrocktv in forum Authoring (DVD)Replies: 1Last Post: 11th Jan 2009, 16:57 -
Convert AVI with AC-3 5.1 channel audio to DVD?
By radiikal in forum Video ConversionReplies: 4Last Post: 20th Aug 2008, 23:56 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 17:47
