I would like the capture program itself and takes charge of deinterlacing, cropping and encode for the video is not so heavy. In this way since then I have not lookin for other external programs to prepare the video.
Results 1 to 11 of 11
Try AMAREC TV.
Link: http://www.amarectv.com/download/amarectv310.zip -
I tried it, it seems very good but has watermark on the videos I recorded ..
Can I remove it?Last edited by dandorf; 26th Apr 2015 at 08:49.
Very easy. Just select another codec like X264.
Read both tutorials (Made by VH member, TheThrillness) :
Progressive Capture
Interlaced Capture
Very useful
What is the difference between "Progressive Capture" and "Interlaced Capture"?
I downloaded the Yua to encode the videos ... But I have used with videos recorded in TotalMedia 3.5 and the sounds I always offsets. The game is one of WiiWare (Adventure Island), even though I tried to change the settings, always came the sound outdated.
He would have to record with the AmaRecTV necessarily to run the encode in Yua? In that case, I do not know how encode videos previously recorded with TotalMedia 3.5
Thank you very much for everything. -
I've tried with AmaRecTV. I like the program a lot but I just CANT get deinterlacing to work. Tried with the different modes and top/bottom fields and it looks ok in the preview but the recorded videofile remains interlaced?
I tried with Open Source Broadcaster which is totally not meant for capturing Hi8 and VHS from a camcorder, in itself, but I feel it did a pretty good job. Using Yadif x2 and 50 FPS file I got nice a smooth video compressed with X264. -
Capture in lossless and interlaced form. Correct defects in the capture in lossless and interlaced form. Edit the capture in lossless and interlaced form. Avoid compressing and de-interlacing until the end. Encode once, going from lossless to to the final compressed format if possible. (Ideally you would compress from lossless directly to HEVC.
I never deinterlace interlaced captures, but I'm pretty sure you can deinterlace with something other than HandBrake. Create your own thread and ask about how to go about deinterlacing and how to go from whatever lossless codec you are using to HEVC.
seeking recommended hi8 capture guide using hardware mentionned
By buyabook in forum Capturing and VCRReplies: 53Last Post: 26th Jul 2015, 12:38 -
Current recommended workflow for analog capture to H.264 'archive'?
By Killer3737 in forum Capturing and VCRReplies: 24Last Post: 26th Apr 2015, 10:24 -
Recommended Capture Device for Splitter
By Iwill in forum Capturing and VCRReplies: 4Last Post: 17th Jan 2015, 10:21 -
Recommended video capture software
By richards1052 in forum Newbie / General discussionsReplies: 0Last Post: 24th Jan 2013, 16:15 -
Recommended video editing program?
By Hiku in forum EditingReplies: 2Last Post: 13th May 2010, 15:16
