Hi.
I'm new here. I just bought Aiseesoft HD Converter for Mac. I tried the demo and it seemed to work fine, but it only will record 5 minutes, so I didn't see a size problem at the time.
Now, I've bought it, and yes, it's converting, but it's making the files huge. A 20 minute file is taking up almost 17 gigs. To me there seems to be no compression at all, or am I just misreading the situation?
I am trying to convert Nikon .mov files, to files that I can use in FCP6 without having to render every time I make a change. I found one blog from a couple of years ago that said use the "Apple ProRes 422(*mov) which I did. But it also says to use H.264/ACV MOV for the output format. But I don't see that as existing, and it seems I can only choose one or the other if I were to choose anything else with the H.264 compression. Yet, in properties, it states that FCP setting uses H.264. However, since they're so big, I need to know if they *can* be compressed more, or if I need to buy extra drives.
Can anyone help? By next week I'm going to have to start dumping more footage from four more classes, and I need to know which direction to go.
Thanks.
Caat
APPLE ProRes is huge and can't be compressed more. Especially if your video is in HD.
Trouble with Aiseesoft
By timboothe in forum Authoring (DVD)Replies: 3Last Post: 13th Jan 2014, 13:27 -
Help please with Aiseesoft trim function,
By cromwell in forum Newbie / General discussionsReplies: 10Last Post: 16th May 2013, 06:50 -
ripping/converter software for Mac
By tjgrindsted in forum MacReplies: 1Last Post: 13th Apr 2012, 13:31 -
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 05:04 -
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 05:45
