I have a DVD. it has 2 titles. I want to re-rip it so it has 1 title: no menu and I can watch the whole thing straight through.
I have dvdshrink to rip it with. I can do several things with that:
1. create an .iso with 2 titles and nothing else
2. create two .iso's with 1 title each
3. create a folder with video files representing (1) or (2) above
someone said DVD Rebuilder can join titles. I gave it a whiz and did not see that option anywhere. also I don't see the point in using it, when you can use DVD Decrypter, except maybe better quality.
someone said DVD2one can join titles. I didn't see that option there either. using it resulted in a folder with files representing a DVD with the 2nd title and simply omitted the first. not at all what I was after.
how do you join multiple titles?
Results 1 to 14 of 14
You said the DVD contains both titles, right? So, after playing the first one it goes back to the menu and you have to click something to play the second? If so, you can change the command at the end of the first title so that it goes to the second title directly. There will be a split second delay but you should be okay with that. PGCEdit is the tool for the job. You can also have it skip over the menu and begin playing the first title right away.
Or follow Baldrick's suggestion. -
Check into DVDDecrypter's FILE SPLITTING - NONE options/settings. It might be able to give you one, giant lump of video even with two titles involved.
Click on reauthor... Then I can't remember any more. I last used it around 2007.
You can't use DVD Shrink to merge two titles into one - for that you need VobEdit.
You can use DVD Shrink to do it.
I made a short tutorial on how to do it: https://youtu.be/Ly9ABSFefYo -
Doesn't that procedure still leave two separate titles on the DVD?
I have a DVD. it has 2 titles. I want to re-rip it so it has 1 title: no menu and I can watch the whole thing straight through. -
You are right. dvd shrink makes 2 titles/tracks.
Maybe easier to reauthor with something like dvdstyler. -
Even if it produces two separate titles, when played one after the other there will be only a split second pause going from the first to the second. I think Dr_Sanguinary might have been under the impression the playback might stop after the first and he'd have to then choose to play the second. My guess is that keeping the two titles as long as they play one after the other will be fine with him. After all, he said:
Exactly. The DVD will still have 2 titles, but they'll play through over and over again without stopping. So problem solved.
What if you want to create a MP4 file from the two titles that DVD Shrink creates? (BUP, IFO, VOB)
Ripping DVD with multiple titles
By Fantome in forum Video Streaming DownloadingReplies: 2Last Post: 14th Feb 2014, 14:46 -
By VanZan in forum DVD RippingReplies: 8Last Post: 6th Aug 2013, 18:03 -
Title set with multiple titles
By skaleton in forum Authoring (DVD)Replies: 1Last Post: 27th Jun 2013, 14:58 -
What software is best to use for multiple titles with multiple scenes?
By usalabs in forum Authoring (DVD)Replies: 8Last Post: 1st Nov 2012, 23:10 -
Combining multiple titles into one
By augerpro in forum Video ConversionReplies: 2Last Post: 22nd Sep 2011, 16:50
