Hello,
I try to undertsnad the meaning of max reference number.
I have a raw H.264 video in which this number is 2 but I see no B-frames in it:
https://drive.google.com/file/d/0B22GsWueReZTanpUblJhVjdvYnM/view?usp=sharing
Does anyone knows what's the meaning of this reference number?
Thank you,
Ran
Assuming we are using the same words for meaning the same things...
http://en.wikibooks.org/wiki/MeGUI/x264_Settings#ref -
Hi El,
Yes, that's what I meant. Thanks.
The strange thing is that in the h.264 analyzer I see 2 parameters:
DPB Size=13
Max Ref Frame Number=2
While the wiki link shows only definition for "ref" : Controls the size of the DPB (Decoded Picture Buffer).
Thanks,
Ran
Number of reference frames x264
By Surlias in forum Newbie / General discussionsReplies: 17Last Post: 17th Mar 2019, 14:32 -
WANTED: PSNR comparison of X.264 and x265 codecs with their max settings.
By Stears555 in forum Video ConversionReplies: 5Last Post: 20th Nov 2013, 10:19 -
H.264 settings in MainConcept Reference
By nharikrishna in forum Video ConversionReplies: 4Last Post: 19th Jun 2013, 13:36 -
H.264 reference frames
By grinder_luck in forum ProgrammingReplies: 1Last Post: 13th Jul 2011, 12:39 -
ffmpeg Number of stream maps must match number of output streams
By tmiller_15 in forum Blu-ray RippingReplies: 1Last Post: 13th Nov 2010, 07:20
