Hello. I am a hobbyist cinematographer for many years shooting mainly events and small projects. I generally use a Panasonic AG-HVX201 camcorder which I'm very happy with.
I wanted to also get a cheap backup camera (actually, the cheapest/good camera I could find) to use just in case and settled to the Sony HDR-CX240. My only concern is what happens when the video recording exceeds the 4 GB limit on FAT32 memory cards. Does it automatically split the files or does it stop recording? I read that some cameras have this feature and some not. The format is AVCHD of course and I think the container is .mts .
Is anyone able to provide me with more information?
So that means I can set it to record for over an hour and then join the clips inside the editing program, right?
I have been working only with DV tapes for event recordings so I didn't know how these cameras handle the files. -
Yes. If you do it properly (transfer directly from the camera's usb port, or import the entire card folder structure into i.e. Avid, Premiere or Vegas) the clips will be "automatically" joined with no sync issues, etc.
If you import only the mts clips, you can butt them end to end in your NLE, but there is the possibility of skipped or duplicated frames or sync errors. But remember, this is a consumer camcorder, so as long as you don't try to outsmart it, it will do what you want.Last edited by smrpix; 25th Apr 2015 at 09:42.
Adobe Premiere Pro CS5.5 Import Export Settings for Sony HDR CX240
By Andalite in forum EditingReplies: 7Last Post: 1st Aug 2014, 05:52 -
Capturing vid from Sony HDR-HC5 via HDMI w/ Sony movie studio?
By thxphotog in forum Capturing and VCRReplies: 3Last Post: 5th Jan 2014, 20:37 -
sony Vpro 10 "video longer than sound" sony hdr-cx116e, part II
By cesarin in forum EditingReplies: 16Last Post: 11th Oct 2011, 07:20 -
Looking for a used Sony HDR AX 2000
By Israelswg in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2011, 03:52 -
SONY HDR-XR500E to PC
By amitabhbansal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 16th Oct 2010, 05:37
